Results 1 to 2 of 2
    Default 2018 Engine Computer BMW 430i - P0430 delete
    Hello.
    Need help disabling catalytic converter efficiency too low or below threshold in this ECU
    P0430 - converter efficiency below threshold 0r
    189991 - Catalytuc converter efficiency too low
    i want this dtc be remove from the ecu dump, so that it wont monitor and report
    i dont want the oxygen sensor bank 1 sensor 2, to monitor the convertor as the converter got choked and it is removed
    thank you for helping, am grateful
    jurebv's Avatar
    Dec 2017
    Croatia
    file is crypted , either slave , bad read or you posted backup file instead of MPC
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  3. The Following User Says Thank You to jurebv For This Useful Post:
    forumoto (15th November, 2022)
