Results 1 to 13 of 13
    Mar 2021
    Default Vin number edit help
    Hello. Can anyone edit my Vin Harley Davidson streetglide to 1hd1kbm11gb649185.
    Just tried by my self on p-flash there is Vin on sector 00400 and 00800 i did edited and writing success but when i plug to the bike, scan with obdstar tools, some parameter not showing and Vin also not showing on scaner.
    Note: bike can start normaly. 2014sgdonyWhite.zip
    Sent from my Redmi Note 9 Pro using Tapatalk
    nacar's Avatar
    Dec 2012
    south america
    obdstar will release the update for harley soon , vin edit ...etc on ms80etc.
    have you finish this byke >>streetglide<<
  3. The Following User Says Thank You to nacar For This Useful Post:
    Erlan (19th November, 2022)
    Mar 2021
    Quote Originally Posted by nacar View Post
    Instresting. Can you show me link or pic ms80 please...
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Erlan View Post
    your pflash seems OK...
    but your EE, is not OK...
    you read it as xep 768 unsecured...?
    Mar 2021
    Quote Originally Posted by figani View Post
    I read secure mode
    figani's Avatar
    Feb 2018
    I read secure mode
    your EE is useless...
    must be unsecured...
    better read all again, and twice and compare...
    Mar 2021
    yes it seem wrong, please check and how to fix this
    nacar's Avatar
    Dec 2012
    south america
    hi m8, just rewrite the correct vin in the consistent ee & done
  10. The Following User Says Thank You to nacar For This Useful Post:
    Erlan (22nd November, 2022)
  11. #9
    Mar 2021
    thx, what tools u are using,? and how to read secure, my vvdi show firstime reading was canot read partition, and and ask to read manually i manage to re write pflash and ee with modified vin but the result on the diagnostic code now lost com throwing code U0121, U0100 ,U0184 AND even worse bike canot start with kess trying to read show ID not recognize.
  12. #10
    nacar's Avatar
    Dec 2012
    south america
    Ok understood, can you comunicate to ecm and BCM with any scanner Normal? What's bike is your?
  13. #11
    nacar's Avatar
    Dec 2012
    south america
    it is very likely that this file is corrupted these dts U network can happen when the ecm unit does not have the same vin as the cluster, so if you read these codes in the ecm, I am reading both with the upa programmer, with launch and with kess whatever
    now in editing you have to be careful, the vin is repeated in several lines, hope this helps
  14. #12
    Mar 2021
    still no start normaly. bike start for 2sc and dies. i plug my obdstar diag for harley canot identify vin..maybe this cause for this issue. but when i check the bin file the vin is correct on pflash they are two line on 00400 and 0800 and ee also showing vin correct. am not sure what else
  15. #13
    nacar's Avatar
    Dec 2012
    south america
    hi dear, you made the marriage of the ecu with the bcm my friend, if you changed or deleted the marriage data in the flash of the ecu, then it will not work, it will give exactly this symptom of starting and then dying. it will only be necessary to match the files, which obdstar are you using, if it is ms80, do it in 1s and in 1 click
