Results 1 to 3 of 3
    Nov 2022
    Default Astra K 2017 dpf map issue
    hi.
    hope someone can help me. i had dpf removed and deleted (astra k 2017 1.6 cdti). after about a month a message has come up on the dash saying that the dpf is full and continue driving. cant exit out of the message so i cantr access other menu items such as mpg or tyre pressure. no fault codes showing on code reader and dpf soot levels are not high enough to trigger the warning. does anyone know what hex codes need to be edited on the bin file to remove this message? i have uploaded the mapped file. if you need original also please let me know
    Jul 2022
    Maybe you must force dpf regeneration before writing modded the file?
    Some solutions require it...
    Nov 2022
    i did this already. it was all fine and working only 1 month later it started showing the message. maybe a time trigger message? i have no clue and even the person who mapped it is shocked.
