Results 1 to 7 of 7
    lmsvvavr's Avatar
    United Kingdom
    Default BMW aftermarket/china key with NXP 26A0700 renew
    So, I have been asked if I could program a new key on a 2007 E90 with the CAS3.
    The owner, brought me a used key, which was actually a key that I have programmed to another car he used to own...
    https://youtu.be/loimdU08JcQ
    Unfortunately, I could not renew this key, and ended up renewing an original BMW key, and programmed it... luckly, it fitted nicely on the aftermarket shell...
    Does anyone can shed some light on where to get the file to renew this key?
    I have used the Autel IM608 to renew the original key, but there is no option to renew the key with this chip...
    Does anyone has a blank file to write on this key, or shed some light on how to proceed to have it done?
    Thank you in advance for your time and help!
    Hit Thanks if helped you!
    Thank You for the help!
    "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
    http://www.youtube.com/c/LMAutoRepairs
  2. The Following 3 Users Say Thank You to lmsvvavr For This Useful Post:
    fuzz1 (19th November, 2022), VDO (19th November, 2022)
  3. #2
    europe
    I have same question I have some locked alftermarket renault card,fiat keys with 26A0700 chip can these be renewed
    EU
    I try to unlock same key before but only way to unlock this key is with CAS file that you use to programme it early
    HTH
    lmsvvavr's Avatar
    United Kingdom
    Quote Originally Posted by davorOS View Post
    HTH
    Too late for that...
    Don't think I saved such files...
    Thank you
    Apr 2022
    Germany
    Do you have some programmer which can program pcf chips?
    Something like pcf prog or Vvdi prog or rem-unlocker?
    electronistul21's Avatar
    Nov 2011
    galati,romania
    For reset can use VVDI Prog .Desoldering IC from PCB and put in ZIF adapter , set how PCF7961.After this method is posible notwork remote . Another way is reset with HT prog ,where have ,,RESET BMW KEY frm CHINA".Have wiring diagram inside not need desoldering IC.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
    Dec 2021
    Spain
    Hello!
    I have the same question, bmw key with 26A0700
    I still have the original file from hitag2 and I can save the key data from CAS
    Would be possible to unlock china keys? VVDI mini/prog can't renew
    I have cas dump, so Im able to get isk. I can read again the key with hitag 2 but I cannot modify anything
    Thanks!
