    Dec 2012
    EU
    Default How to clone SSD?
    Hi all whats the easiest way clone 512SSD to 2T SSD ..
    Sent from my SM-G965F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    Quote Originally Posted by gttuning View Post
    You can use Aomei Backuper or Easeus Partition. Quite easy I think.
    Dec 2022
    I used Macrium Reflect, it is excellent.
  4. The Following User Says Thank You to ScottyP60529 For This Useful Post:
    kapadokya (10th January, 2023)
    kapadokya's Avatar
    Jun 2022
    Quote Originally Posted by ScottyP60529 View Post
    best app for me
    Time does not change anything
    Feb 2022
    At first make sure that HDD is not filled above 500GB. Delete anything not wanted to make disk use below 500 GB plus overhead for data moving.... let say make 600 GB free. Then connect SSD to system, boot from some recovery drive with disk cloning software and clone HDD to SSD. After cloning replace HDD with cloned SSD and you are good. Particularly in last year for me Lazesoft Disk Image & Clone on Hirens BootCD PE on USB stick did the trick without any issues.
    Sep 2024
    Denmark
    i always use:
    minitool partition wizard
    Clonezilla
    Minitool also have a usb version, so you can boot directly from the usb.
