Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    Sep 2020
    PL
    Default Godiag GD101, VNCI J2534 Nano
    New interfaces from aliexpress.
    Are they worth anything.
    Do they work like openport 2.0
    Can work with GDS2, ODIS, Consult 3+.
    Maybe someone has experience with this
    Mar 2019
    Dundee
    Been looking at this too bud, couple of videos online but not seen Odis working yet
    Sep 2020
    PL
    According to user feedback, VNCI operation j2534=GodiagGD101 confirmed with techstream, odis, jlrsdd, hds, gds2, in the range of 1 line can, 1 line K
  4. The Following User Says Thank You to torzet For This Useful Post:
    boner200 (30th January, 2023)
    Mar 2019
    Dundee
    Works with Odis I have tried it, Jlr sdd, Gm2 and Honda do see it but I have not tested on car yet.
    Jan 2022
    I purchased one and it does not change baud rate when attempting a programming sequence, They claim it functions same as the Openport 2.0 but that is a false claim.
    Jul 2022
    [引用=西北;4466634]我购买了一个,它在尝试编程序列时不会改变波特率,他们声称它的功能与 Openport 2.0 相同,但这是一个错误的说法。[/引用]
    你说的这个问题已经更新,更新固件固件之后就可以了。https://mega.nz/file/YfdyHJSJ#pDtWE8...mnqBxtbMbRmyo8 GD101 GODIAG V1.2
    Sep 2020
    PL
    VNCI Wu
    The new Godiag GD101 driver will probably also fit the VNCI J2534 nano. They may be the same devices but in a different housing.
    Aug 2021
    I bought the pink VNCI Nano to test with Renault Clip, but unfortunately it didn't work. Clip detects it, but it won't even read VIN - tested with both VNCI Nano drivers and all Godiag drivers I could find, also updated firmware.
    I thought that maybe the CAN transceiver chip (SIT1050) is bad, so I tried replacing it with a genuine NXP tja1050, but it didn't change anything. I later also confirmed with an oscilloscope that the can transceiver is indeed working, it's just not talking to the car in Clip.
    It also has ELM327 mode but it doesn't work very well - I ran ELM test in PyRen and it says it has a lot of ELM instructions missing, even some v1.0 instructions. Needless to say, it doesn't work with PyRen and renault cars in general.
    As for VNCI Nano/Godiag compatibility, it's clearly the same device. Funny thing, but I messaged the official Godiag store on Aliexpress to ask for drivers, because the links on their product pages no longes worked, and.... Godiag sent me the VNCI J2534 Nano drivers instead of the Godiag GD101 drivers. So yeah, it's definitely one and the same thing. And btw they still didn't fix the dead drivers link on the product page
    Some pictures for reference, made before I replaced the SIT with TJA1050. Will probably swap it back anyway since it didn't change anything.
  10. The Following 3 Users Say Thank You to ProximaCentauri For This Useful Post:
    Col19 (27th January, 2024), kapadokya (15th October, 2023), torzet (30th March, 2023)
  11. #9
    Nov 2020
    Yes, i know VNCI is stic company zhu engineer tool. rubbish tool,no support and no repair.
  12. #10
    Nov 2020
    STIC company locked all old tools and never support all old tools, in order to let you buy the stic VNCI new tool.
  13. #11
    Jul 2022
    [QUOTE=ProximaCentauri;4516694]我买了粉红色的VNCI Nano来测试雷诺Clip,但不幸的是它没有用。Clip检测到它,但它甚至不会读取VIN - 使用VNCI Nano驱动程序和我能找到的所有Godiag驱动程序进行了测试,还更新了固件。
    我想也许CAN收发器芯片(SIT1050)不好,所以我尝试用真正的恩智浦tja1050替换它,但它没 有改变任何东西。我后来还用示波器确认了罐头收发器确实在工作,只是它没有在 Clip 中与汽车交谈。
    它也有 ELM327 模式,但它工作得不是很好 - 我在 PyRen 中运行了 ELM 测试,它说它缺少很多 ELM 指令,甚至一些 v1.0 指令。不用说,它不适用于 PyRen 和雷诺汽车。
    至于VNCI Nano/Godiag的兼容性,它显然是同一个设备。有趣的是,但我在全球速卖通上给官方 Godiag 商店发消息询问司机,因为他们产品页面上的链接不起作用,而且......Godiag 给我发了 VNCI J2534 Nano 驱动程序,而不是 Godiag GD101 驱动程序。所以是的,这绝对是一回事。顺便说一句,他们仍然没有修复产品页面上
    的死驱动程序链接 一些图片供参考,在我用 TJA1050 替换 SIT 之前制作。无论如何都可能会把它换回来,因为它没有改变任何东西。
    zPUVcBv.jpg[/引用]
    Renault Clip is supported. We have discovered this bug and can use it after upgrading,
    PyRen is not supported, this device does not support PY
  14. #12
    Jul 2022
    [QUOTE=Torzet;4481037]VNCI Wu
    新的Godiag GD101驱动程序可能也适合VNCI J2534 nano。它们可能是相同的设备,但位于不同的外壳中。[/引用]
    The two devices are identical, but the drivers are different. It is recommended that you use the corresponding drivers
  15. #13
    Nov 2020
    VNCI is STIC company zhu engineer tool,crap
    Warning:
    zhu engineer never any technical support.
    zhu engineer never any warranty.
    zhu engineer locked your tool anytime.
  16. #14
    Nov 2020
    oh my god, it can not do hscan and mscan, surprise!!!
  17. #15
    Aug 2021
    Quote Originally Posted by VNCI Wu View Post
    Interesting! Was that update released yet? Recently I tried with newest GD101 2.1 drivers + 1.8 firmware and Clip still didn't work.
    Where can I download VNCI drivers if they work with Clip? When I asked the VNCI Nano seller for drivers, he sent me.... GD101 drivers instead. And when I asked a Godiag official seller for drivers, he sent me VNCI Nano drivers instead, but some old version. So it seems that even the (official?) sellers don't see the difference.
