Results 1 to 3 of 3
    May 2009
    North East Lincs
    Default technomate 6900 adding new TP
    Hi i'm wanting to add a new TP. I go to Main menu-Installation-Advance search-Green button add tp then when i press any number the box turn off then back on to the last channel were it was also if i use V+ or V- it turns off the same any help into how to input numbers for a new TP. Looking for channel4
    Thanks Steve
    It's OK i've done it now, deleted a TP not working and it alowed me to input a new TP
    Jun 2009
    go to PID search the tp you want is 10.714 H 22000 but that should be in the memory already try a re-scan if you find it if not use the add TP in the PID sub menu.
    May 2009
    North East Lincs
    Quote Originally Posted by dick b View Post
    Thanks for the reply i had 10.714H already in but got no signal put 10.713H and all worked when i deleted a old TP
