Results 1 to 2 of 2
    Top Poster + the rock's Avatar
    dublin ireland
    Default tune failed dream for dm 800
    There are still some bugs in the software, which can cause this problem too.
    This failure is already known to our development department and we are
    currently working on a suitable solution.
    As long as there is no updated release firmware image available, please
    install this experimental image
    to your box: this was sent to me buy dream to fix tune failed is this not for CLONE BOXES
    http://www.dreamboxupdate.com/opendreambox/1.6/dm800/images/experimental-dm800_20100304.nfi
    dublin ireland
    Default tune failed from dream
    Further you can test the advanced configuration instead of the simple one.
    Please test it by using the manual configuration. In the tuner configuration
    set the config. of the tuner to "extended" (at the moment should be on
    "simple"). Now you can choose which satellite to receive and then use for
    these satellites this settings (Diseqc-mode 1.1, Diseqc
    command transfer (AA), Diseqc repeats on 2 or 3, command or repeating sequence
    may also once activate).
    Once configured for the first satellite please select with the left-right
    buttons of the remote control the next satellite you wish to receive and make
    the same adjustment (just adpot the Diseqc-Port to AB etc.). Please do not use
    the "exit"-button on the remote before all satellites
    are configured correctly. Are all satellite configured, please press the OK
    button on the remote to save the settings.
