Results 1 to 10 of 10
    Nov 2022
    Default VW 24C32 IMMO transfer to 24C64 EEPROM
    Dear all,
    I do a cluster swap in a 2008 Scirocco with a 24C32 EEPROM. It's the small display version like Golf V.
    I bought a 1K8920884 3D cluster from a new Scirocco with a 24C64 EEPROM.
    I read the dumps from both of them and tryed to search the immo datas. In the new one I found it with the help of the VAG Dash Editor's table reference. This contains the address of the IMMO data in the 32-s dump too, but I didn't find anything in that lines.
    It is possible to simple copy the hex values from the old cluster and change it in the new one or it uses a different encription?
    Oct 2014
    Netherlands
    Each cluster uses a unique key to encrypt immo, so you cannot just copy eeprom contents.
    Instead you must use a suitable tool which can read/write immo in plain format.
    Rgs H2Deetoo
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    rafal (19th December, 2022)
    Nov 2022
    Thank you the information. Definitely I need to use VCDS and the other tools.
    Quote Originally Posted by H2Deetoo View Post
    Rgs H2Deetoo
    brend's Avatar
    Oct 2015
    Same where
    ..............clear..............
  6. The Following User Says Thank You to brend For This Useful Post:
    May 2021
    Europe
    You can read and change this (key , power class , mac , cs and another option) with SVCI 2020. But first you have to manipulate the dumps (with CH341A) from the instrument cluster in order to get into a kind of service mode.
    This means that the real estate data from the old instrument cluster can be transferred or adjusted to the new one, so that you don't have to learn a new key. Also from VW 24C32 to 24C64 EEPROM.
    It's been a while since I last did it, but I still have it documented somewhere, but it's all in German.
  8. #6
    Polska
    Please document to copy 24c32 to 24c64.
  9. #7
    rob h's Avatar
    May 2011
  10. The Following User Says Thank You to rob h For This Useful Post:
    brend (16th March, 2023)
  11. #8
    May 2021
    Europe
    Default Dokumentation zum Ändern/Wechsel des Tachometers Golf 6
    I just read your post, in the attachment you will find the documentation for changing the speedometer. But it's in my language. (German)
  12. The Following 3 Users Say Thank You to TurboFerkel For This Useful Post:
    antonypaul (11th August, 2023), twinsen23 (1st September, 2023), ~rexdv~ (17th December, 2023)
  13. #9
    alonedark's Avatar
    Feb 2017
    you have inmo data and other transfer in new dash
  14. #10
    Apr 2025
    Stuck with a similar problem, dont have access to any special tools other than VCDS and dont have the pin for the new cluster
