Page 108 of 854 FirstFirst ... 85898103104105106107108109110111112113118158208608 ... LastLast
Results 1,606 to 1,620 of 12803
  1. #1606
    Mar 2011
    Hello, exus? my English. I shall like knowing if it is possible to reflacher my interface vag 10.6.3 English version in 10.6.3 French version.
    Thank you for your r?ponces
  2. #1607
    Quote Originally Posted by pat04 View Post
    Yes, it's possible, but you need the dumps for french version.
  3. #1608
    Quote Originally Posted by Harry92 View Post
    1062 ept
    here is dump i made with Mprog 3.0a from VAG 106 cable working with VCDS 10.6.2 ENG, can anyone check it?
    Appear like FT232 BM.
    10.6.2 is not with 232RL?
  4. #1609
    May 2011
    Hello, I bought a Chinese clone VAG-COM 10.6 with VCDS 10.6.0. When I connect the cable to the car some modules works fine but some not. When I try to make Auto-Scan it shows me error "Function not supported by the gateway". Is there any possibility how to resolve this problem? Have you ever seen it? I wanted to use older version of VCDS but I'm not sure if I will not destroy the cable. Any help is welcome.
  5. #1610
    Quote Originally Posted by mario21 View Post
    If your interface is really for 10.6, you can use older versions, they will not damage your interface.
  6. #1611
    May 2011
    Thank you for quick reply. So it means that I can use any version of VCDS lower then 10.6.0 and if it will not work I can again install version 10.6.0?
  7. #1612
    DK Veteran mishu_b's Avatar
    Land of Choice!
    yes ... without any problems.
    atb
  8. #1613
    Apr 2011
    how to check it?
  9. #1614
    Open the case and read the chip FT232. Is nearly of the linkage of the USB cable.
    Or.. BM have pins on 4 sides, RL on 2 sides (2 rows).
    Or, BM/BL is a square, RL is a rectangle..
    Sorry for my bad english..
  10. #1615
    Apr 2011
    On the chip there is FT232BL, but in Mprog there si only FT232BM on the list so i choose it and then program my cable.
    Guyz i think i'm a bit closer to sloving the problem:
    And the cable is dead again, if i reprogram it with my modified dump, then reinstall the drivers it asks me again to update it.
    Also VCDS 10.0.6.0 works, but on the startup it says that my software is outdated. I can auto-scan, it connects to ECU, reads my VIN, driver etc. but when i scan car for errors it gives me error that interface is disconnected or k-line stucks etc. and the cable is dead again...
    Any sugestions?
  11. #1616
    Land of Choice!
    have a look to the security bits !!!!!!!! - you have there one problem.
    atb!
  12. #1617
    Apr 2011
    Quote Originally Posted by mishu_b View Post
    atb!
    can you be more specific? i have no idea what are you talking about, sorry :S
  13. #1618
    Any sugestions?
    Problem most likely in dump, it is necessary to look this dump.
    You could send me dumps?
  14. #1619
    Apr 2011
    Quote Originally Posted by XPS View Post
    1062 test ept
    this is dump i modified and got those results with.
  15. #1620
    1062 test ept
    Problem most likely in AT Mega 162 dump.
