Page 110 of 854 FirstFirst ... 1060100105106107108109110111112113114115120160210610 ... LastLast
Results 1,636 to 1,650 of 12803
  1. #1636
    Junior Member calpacint's Avatar
    Far-East
    Default thanks to bibkare and Xoom
    Quote Originally Posted by bibkare View Post
    Mate you don't read just few post above i told you that
    look here http://www.digital-kaos.co.uk/forums...tml#post827461
    you two save my vag908 ,UDFIX work perfectly.Also thanks to Mishu_b and Monacao who saved my opcom 908, few months ago.What a great members we have here.
    Have a nice day.
    peter
  2. #1637
    colleagues good night,
    I bought a vag clone 10.6.2(VAG1062), must have some bug in this soft, I wonder if this cable works with the soft clone 10.63
  3. #1638
    Oct 2008
    On Earth
    Quote Originally Posted by reisxxx View Post
    I don't think so.
    Any other sw will "kill" your tool
    Good luck
  4. #1639
    May 2011
    Default VAG-COM 908.2 ept file ?
    Hello everyone.
    Does anyone can kindly provide FT232RL VCDS908.2 ROJ version and VAG-COM 908.2 ?
  5. #1640
    Oct 2008
    On Earth
    M8 don't boughter it at all
    This versions are not for free.
    Good luck
  6. #1641
    DK Veteran mishu_b's Avatar
    Land of Choice!
    you can use your tool without risk with lower versions ... (10.6.1, 10.6.0, 9XXX, 8XXX)
    if you will use your tool with upper version - your tool might be locked. it depends if your serial is into the block list or not!
    atb
  7. #1642
    Apr 2011
    Please give me what program can make a backup interface VCDS 10.6. How to do it step by step because I do not know how.
  8. #1643
    spychu14's Avatar
    May 2011
    POLAND
    Hello everyone !
    Is it any loader which is changing serial of interface ??
    I want to try change SN to make my interface working with PL version of VCDS.
  9. #1644
    Thanks a lot
  10. #1645
    Hoe i can update 805 to 10.6
  11. #1646
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by dejanmaksa View Post
    You have all informations in this thread.
    Just read it carefully.
    I am not sure if 10.6 is already available for free but you can try 908.0
    Good luck.
    Did it help? Push Thanks below
  12. #1647
    Junior Member max4ever's Avatar
    Romania
    @paffendorfbg Is it the russian version or english version? The EEPROM looks old (2006).Are you sure that the 11.2 version uses the same EEprom?
  13. #1648
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    VCDS 11.2.0-beta,Data 20110305 English.
  14. #1649
  15. #1650
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Surely there must be a way to update it as this seller has?
    VAG-COM Diagnostics Cable VCDS LATEST Version 11.2.0 beta!!!
    It is compatible with all VAG (Volkswagen Audi Group) vehicles:
    Audi, Seat, Skoda, Volkswagen to 2011.
    The cable was tested for AUTOSCAN on VW T5 and Touareg! Now it is fixed and work!
    This is very stable and latest 2011.03.05 version. Not OLD 10.6.3 (2010)!!!
    Beta 11.2 includes everything of v10.6.x + the following improvements:
    Communications with all control modules in VW Crafter ("LT3") light trucks.
    The ability to perform Adaptations in all control modules in VW Crafter light trucks. This is particularly useful in order to be able to reset the Service Reminder Indicator.
    Improved CAN TP2.0 Retry Scheme for more reliable communications.
    Fixes for module-mapping hang-ups in some late-model radios.
    Support for new VW control module addresses.
    New version 1.84 firmware for HEX+CAN interfaces restores VAG-Saver functionality even when "Boot in intelligent Mode" is active.
    Enhanced Subsystem ID info in Auto-Scan.
    Updated CODES.DAT file now with over 16,000 codes.
    http://cgi.ebay.co.uk/VAG-VCDS-11-2-0-HEX-USB-CAN-VW-Audi-Diag-10-6-3-/110692934075?_trksid=p4340.m263&_trkparms=algo%3DDLSL%252BSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%252BDDSIC%26otn%3D8%26pmod%3D110692456551%252B110692456551%26po%3D%26ps%3D63%26clkid%3D184115961833859793
    This is actual screen shots of the VCDS 11.2.0
    if anyone finds a way let me know as i tried to code a towbar into a 2011 VW Caddy with v10.6 but was unable to
    many thanks
