Page 111 of 854 FirstFirst ... 1161101106107108109110111112113114115116121161211611 ... LastLast
Results 1,651 to 1,665 of 12803
  1. #1651
    Shmortz's Avatar
    in the middle of nowhere
    there is a solution for the latest beta version, I didn't test it, if someone want to do it ok, then post results here
    http://rutracker.org/forum/viewtopic.php?t=3585870
  2. #1652
    POLAND
    Quote Originally Posted by Shmortz View Post
    I tested,everything working but only on ft232BL/BM
    VW Passat 1.9TDI Variant 1xxKM/3xxNm by YaCa
    *VCDS10.6.4*MPPS*GALLETTO1260*VAG-K+CAN2.5*VAGTACHO3.01*WinOLS 1.7*
  3. #1653
    In that .ept is forced usb 1.1, bus power is rised to 100 mA, and 2 options selected (compared with 908.ept).
    Is OK?
  4. #1654
    May 2011
    Hi, I have Chinese clone VAG-COM 10.6 with VCDS 10.6.0. Because there are still some problems with the cable ? it is not possible to make Auto-Scan, some modules don't work, I would like to use dump and soft 908. I read almost whole this thread but I'm still not sure what I need.
    My cable has FTDI FT232RL, Atmega 162V, flash 1.81.
    And now questions:
    1) Do I need all 3 dumps (2 for Atmega and 1 for FTDI) or is it enough to use .EPT dump for FTDI (version 908)?
    2) I downloaded .EPT dump for FT232RL from http://www.digital-kaos.co.uk/forums...tml#post816515 but when I opened it in MProg it shows me "Device type: FT232BM". So can anybody confirm that this dump is really for FT232RL?
    Thank you for replies.
  5. #1655
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    does anyone know if you can clear crash data from srs module
  6. #1656
    tehnosoftex's Avatar
    Romania
    Hi, a friend of mine has bought a vcds 10.6 and he connect it on the internet and his interface stop to work. I have found here on dk several dumps. I try first time with 908. All went good, but if i connect on the car I cannot see any module. If I push about, the serial number is there , it is fully registred/activated every thing seems to be ok. I try also vers 11.2. Same thing. If I test the interface I have Interface OK, status ready k1 ok k2 ok can not ready. The interface is with ft232bm. When I feed up the interface at 12v the led glows red and then green and stay green. Any one can give me a suggestion? It can be erased also the pld?
  7. #1657
    Quote Originally Posted by tehnosoftex View Post
    Hi, a friend of mine has bought a vcds 10.6 and he connect it on the internet and his interface stop to work......................................
    Uninstall the vcds software (it is now transformed into something else, dangerous for your interface) ! Remove rt-updater from start up.
    Reinstall the vcds 11.2 (or what ever dupms you have) into a DIFFERENT location (not the old one!). BUT do not install drivers !!!
    Re-flash the interface with 11.2.
    Put interface into computer , drive it manually to install drivers into the new location (where it is vcds.exe)
    Must work.
    Try not to use internet while vcds is runnig.
    Quote Originally Posted by teerak2uk View Post
    As I know it can't . Some people trick this module by adding , if I remeber well , 2 resistors (2.2 ohms?). You can ask liviudiaconu he had that problem solved as i know)
  8. #1658
    Junior Member bat21's Avatar
  9. #1659
    May 2011
    Are you shure it works in RL interface?
    I ask because I have a blocked chinese cable VAG106, with FT232RL, and after dump 11.2 firmaware, the test says: Port ok, Interface found, type Ross tech...., K1 and K2 ok , but status failed self test. Do you hace any idea about what was wrong?
    regards.
  10. #1660
  11. #1661
    May 2011
    I saw your post. Additionaly to reflash with 11.2 dump, have you done anything else? like some hardware modification, etc..)
  12. #1662
  13. #1663
    May 2011
    bat21,
    what do you mean with a good loader?, could you explain or describe the step that you followed to get a succesfull reflash and a working vag-com?
  14. #1664
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Default ept to 11.2.0
    Hello DK?s
    Does any member of this forum has dump to FT232RL.ept ?? to version 11.2.0_beta ??
    BR, Fifas
  15. #1665
