Page 113 of 854 FirstFirst ... 1363103108109110111112113114115116117118123163213613 ... LastLast
Results 1,681 to 1,695 of 12803
  1. #1681
    LT & ES
    Quote Originally Posted by vyger View Post
    With rusian dump come two files vcds_rus.exe and vcds_rus.dll. I installed original vcds 11.2 beta from Ross-tech, then I copied both vcds_rus files to installation directory, and I executed vcds_rus.exe instead of vcds.exe original, but don?t work. Over what file I have to apply the patch loader that you tell, over Ross-tech original vcds or over vcds_rus.exe.
    regards.
    Those files are to translate the programm in russian lenguage.
  2. #1682
    regards.
    It works with original software without patches.
  3. #1683
    May 2011
    Quote Originally Posted by XPS View Post
    XPS,
    I try to reflash my vag106 with rusian FW 11.2, but doesn't work. My interface has an FT232RL. If you have some idea to solve it, I would thank you.
  4. #1684
    May 2011
    Quote Originally Posted by bat21 View Post
    Yes, good way
    Well, I try to create a loader with dup2 and address and values you've indicated in previus post, but my reflashed vag still doesn't work. When I test VCDS 11.2 beta return all ok, except status: Failed Self Test.
    What do you think?
  5. #1685
    Junior Member bat21's Avatar
  6. #1686
    Member thesaint4's Avatar
    May 2011
    Douglas Isle of man
    Hi Igorm,
    I am a mechanical engineer and locksmith (I design tools for the safe and vault industry) We are new to the auto area and want to get involved. My business partner is a software engineer, his specialism is the windows operating system. We are happy to help in that area, he uses borland C++. Please message me if you would like to talk more!
    cheers.
  7. #1687
    May 2011
    Can i Use this Adapter?
    Vagcom Vag10.6 diagnostic cable VCDS HEX USB Interface for VW/Audi
    This must be the same:
    VCDS10.6.2 VAGCOM HAX CAN Activated WAG Kable Volkswagon
    What is Micro Can?
    I dont want to buy in China. So i found this in Spain.
  8. #1688
    May 2011
    Broked my VAG10.6 diagnostic cable VCDS DUAL-K&CAN...
    I managed to flash it in 704 but is it possible to switch to 11.x?
  9. #1689
    May 2011
    send me pm what did you do,
    link to loader 11.2 and Chinese software 10.6
    Dear Bat21,
    yesterday night, after I sent to you the files you requested, I tried again, with rusian dump and a loader created as you specified, and the vag cable It's alive!!!. Thank you, you are THE MASTER!!!.
    There still is a little problem with drivers, but nothing that avoids me to connect with my car's computer. Apparentely VCDS11.2 beta drivers don't detect well chinese cable, then I have to run VCDS10.6 to load this version's drivers, next without doing anything else with 10.6 , I close it, and finally I open 11.2 beta -> test -> all ok , status ready. Up to now it works for me. I used AutoScan to gather general modules information of my car.
    Thank you very much!!!!
  10. #1690
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by tibo View Post
    yes - it is possible to flash with what would you like (of course available for free)
    all you need you can find here in this section ... just spend few hours for this job.
    atb
  11. #1691
    May 2011
    Yes, it's possible. I reflashed my chinese vag10.6 with FW11.2 beta, and I created a loader for VCDS with dup2, as Bat21 told me. And it works!!!
  12. #1692
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    what was the exact procedure you used as i have 10.6 and is v11 buggy as it is a beta version
  13. #1693
    taking everything into consideration I should to exercise great care of China-Clones.
    Where to buy for example a functional VCDS 805 oder 908 clone via Paypal? Its only for a Golf MKV...
    Very Thanks to your help!
    erik2005
  14. #1694
    May 2011
    I don't know why, but the last two message I posted about how to reflash VAG with FW11.2 beta has been erased. Search in Rapidshare the file VAGREVIVAL.rar.
  15. #1695
    LT & ES
    why not just close this topic , it ruins moderators bussiness! 114pages about nothing no files , no links , no helping info ? Is this commercial forum ? If my post will dissapear - no problems , just my opinion
