Page 116 of 854 FirstFirst ... 1666106111112113114115116117118119120121126166216616 ... LastLast
Results 1,726 to 1,740 of 12803
  1. #1726
    Worked 10.6.4 and 11.2
  2. #1727
    RF
    Quote Originally Posted by yas200979 View Post
    Free for ALL vcds. Worked original soft ROSTECH site.
    Damp 1.84
    This that most, as on rutracker.org. Works with FT232B. So works with FT232R if to use loader dup2. I have written, that the second time not to download.
  3. #1728
    Quote Originally Posted by KenshinPT View Post
    Yes, it's possible to upgrade FLASH without ponyprog or other ICSP. Lot's of DK members have done that and it's a very simple procedure.
    I am not sure if EEPROM is also possible but I believe that it is.
    Regards.
    Where is described the procedure?
    About FTDI_232 from rutraker, i don't understand why have USB 1.1 setting, why bus is rised at 100 mA (10.6 and 908 have 50).. that ept file is different .
  4. #1729
    Thanked - 0!!!!
    Worked ORIGINAL sofware!!!!!!
  5. #1730
    Spain
    THANKS yas200979, but, it?s only for 232BL & 232BM, no? For the 232RL need a cracked software, correct?
    Can you share photos working with the original software?
    Full?
    Thanks u man.
  6. #1731
    Usa
    yes,work with the original software.full
  7. #1732
    Spain
    With de 232RL? or only in BM/BL?
    Thanks!!
  8. #1733
    Quote Originally Posted by DaniXDX View Post
    Thanks!!
    Only BM/BL
  9. #1734
    Spain
    Where i can find a Vag 106 to buy with de BM/BL? jeje, it?s the cuestion..
  10. #1735
    blackpirate's Avatar
    Jun 2009
    hey guys
    i got a question for you experts:
    after a friend done service reset on Passat 2007, dash shows this:
    "trAxxx" without quotes of course!:P
    and "xxx" are last digits of the mileage!
    Mileage was not altered!No errors on dash or dead fuses!
    Entire value can be seen using vcds! dash and ecu!
    any ideas? how to fix this!?
    thnx
    If freedom is outlawed, only outlaws will have freedom!!!!
  11. #1736
    DK Veteran KenshinPT's Avatar
    PT
    To use this 11.2 dump we should change the system date, right?
    But 11.3 is out and maybe the 11.2 dump is not yet banned on this new beta version.
    http://www.ross-tech.com/vcds/download/beta/current.html#11.3
    Later I am goona try it
    Did it help? Push Thanks below
  12. #1737
    Afaik you must set back the system date (before june 2011?).
    In another thread i read that this dump is already blacklisted by 11.3, but maybe you have more luck.
  13. #1738
    Hi fellas, having read through this thread I see repeated comments about the perils of using crappy Chinese interfaces.
    If you aren't buying from China where are you buying them from?
    I've seen a schematic drawing and PCB layout posted in this thread is this what some of you usd to build a DIY interface?
    Thanks.
  14. #1739
    Austria
    further ver blocked because leaked.
    one day public, second day new beta out, and bye bye..
    good job leechers
  15. #1740
    Spain
    Quote Originally Posted by paro44 View Post
    I listen the same... but, in the newer 10.6.3 /11.2, must set back de system date? :S
    Thanks.
