Originally Posted by
pirolla
I have a cable which came with the VAG-COM 409 software. It only has two ICs: a LM393 (Voltage comparator), and the FTDI FT232BL. I took a picture of it. The LM393 is soldered on the other side.
I read that with this cable, I'll only be able to use VAG-COM 409 and VCDS Lite. Is that correct? I got both softwares cracked just to see how they go, and everything seems to be fine.
But what I'm realising from the posts is that there is another kinf of cable, with a little more hardware on it (like a CAN module), and that Ross Tech is blocking some features in their software via FIRMWARE. Is that why people are reflashing their units: so they can run newer software versions with all the features unlocked??
If so, what kind of cable should I look for in ebay ? One that comes with a VCDS software? And then I follow the tutorials to reprogram it?
Another question: is there any way to reprogram the injection tables of a VW? (without speding a lot of money, of course!). I have a 2001 mk4 golf, with 266 thousand Km, and want to play with it a bit =D And my friend has a Passat B3, 1996.
Cheers
