Page 119 of 854 FirstFirst ... 1969109114115116117118119120121122123124129169219619 ... LastLast
Results 1,771 to 1,785 of 12803
  1. #1771
    @KenshinPT:
    when testing with 11.3 , how many times have you test the interface and did you unplug/plug before each test both part (OBD and USB) of the interface ?
    Because if you have tested only ONE time it is , I am afraid, irellevant. It should be tested at least 2 - 3 times (with plug - unplug of the interface each time).
  2. #1772
    Jun 2011
    Quote Originally Posted by bibkare View Post
    First remove stc chip like i marked in pic then you will probably need to reflash ftdi eeprom after that reflash atmega with 908 dump (flash and eeprom) configure security bits and you will be good to go. I had good experience with that kind of hardware.
    All you need: Dump VCDS 908.0: http://rapidshare.com/files/41605396...ash__908.0.rar
    FTDI Eeprom for FT232BL and FT232RL: http://www.digital-kaos.co.uk/forums...tml#post816515
    I'm new on this Forum... I've read lots of threads about reflashing EEPROM for china cables. I've got a 106 cable. Can I use your guide for making my cable working again?
    When I conntect to the car with the cable, the LED turns green. when I plug in the USB into my PC i goes over to red... The Test on VCDS 908.1 says "cable found, port ok and so on" but it always says that I'm not connected with my car?!?! So is your guide the right one for me?
    Thx and greetz from a new user ;-)
  3. #1773
    Mar 2011
    Hello everyone,
    I tryed to flash my 908 with dump 11.2 for atmega but in the archive posted from rutracker is a single file and my programmer asks for 2 files (flash and eeprom), what can I do to write it in Atmega ?
    thank you!
  4. #1774
    Jan 2011
    Quote Originally Posted by surubache View Post
    Hello everyone,
    thank you!
    Its simple:
    you can open this file by ponyprog (before you need to choise chip Atmega 162 in ponyprog), then save flash files as flesh.hex, and save eeprom as eeprom.bin
  5. #1775
    May 2011
    Hello everyone,
    thank you!
    rutracker's file include both, if you use ponyprog, you only need to select ATMEGA162, then erase all device, set memory flag according rutracker, and then write both memories cliking on "write device" button.
  6. #1776
    RF
    .....my programmer asks for 2 files (flash and eeprom), what can I do to write it in Atmega ? ......
    These are various variants.
  7. #1777
    May 2011
    Default VCDS10.6.3 original from Ross-tech
    does someone have the original version of VCDS10.6.3 from Ross-Tech( not that one come with chinese cable) and share it?
  8. #1778
    @KenshinPT:
    I have tested 11.2 dumps with 11.3 software version so as I expected, the interface was deleted. So just limit to the other versions.
  9. #1779
    Oct 2008
    On Earth
    Great job dodobird.
    You tested what we aspected that will happend.
    ross-tech when upgrade the softwear they do to blacklist the clone serials and for a littel bit to introduce something new.
    When they saw that the new dumps show up they blacklisted.
    I suppose that on their web shop they have VCDS 10.6.4 with blackliste for this dumps too.
    Good luck
  10. #1780
    RF
    Quote Originally Posted by vyger View Post
    ...VCDS10.6.3 from Ross-Tech( not that one come with chinese cable) ...
    I have loaded the program for you
  11. #1781
    May 2011
    Default Small remaining problem
    Thanks Bat21 guidance and VCDS10.6.3 install file uploaded by Magadan, I have a VAG106 chinese cable working with Fw11.2 and VCDS10.6.3, but, always there is one but, there is a little remaining problem, less than a problem, an complication:
    the procedure to get a sucefull conection is the following:
    first I plug VAG106 only in USB port(not in the car),
    secondly, I have to run VCDS10.6, the version installed from cd that come with the cable(panda face cd),
    ones VCDS10.6 main windows opens, I plug the other end of cable in car port.
    After that I close VCDS10.6. I get ERROR 3, I have to disable and enable again Ross-tech Direct USB interface from control panel.
    Finally I can run VCDS10.6.3 and run test or whatever, and it works.
    I figure that all this is related to FTDI RL, but I don't know how to fix it.
  12. #1782
    Oct 2008
    On Earth
    I'm sorry I do not follow you.
    Please tell me , if you have an ft232RL based interface and you tried to use the original VCDS 10.6.3 interface how do it worked?
    Did you try an Autoscan ito a car or what?
    I asked you this just becasue I know that the interfaces FT232RL based works with modified ( cracked ) softwears.
    Good luck
  13. #1783
    spychu14's Avatar
    May 2011
    POLAND
    Try this installer
  14. The Following User Says Thank You to spychu14 For This Useful Post:
    clauberty (24th August, 2014)
  15. #1784
    RF
    Please explain explicitly to me how you find addresses in a file (???) with which it is necessary to replace? It is possible a personal meeting.
  16. #1785
    Oct 2008
    On Earth
    Quote Originally Posted by spychu14 View Post
    Try this installer
    This is for RL or for BL/BM tools?
    Good luck
