Just to share my experience while using 11.2 beta dump.
VCDS 11.3 beta: Sofware detects the cable as an original but when I try to communicate with the car the communication is very unstable and faulty.
VCDS 11.2 beta: After testing software says: "Cable not recognized". I did it again after a fresh reflash of ATMEGA and FTDI's EEPROM and nothing. I used two releases I have of this beta.
VCDS 10.6.4: Works 100%
VCDS 10.6.3 and later: Not tested... because those versions are obsolete.
If anyone is working with VCDS 11.2 beta please share your release with us because I have two and none work.
Thanks and good luck
@KenshinPT please don't worry
It is just fine
Change the date time to 2011-05-25 and let me know if it's working, please.
I'm talking about VCDS 11.2.0
Good luck
KenshinPT
Did you use 11.2 dump with VCDS 10.6.4 and version date 20110418?
You should try using "Runasdate" with the Beta versions, to avoid out of date messages
First to answer your question I need to know if there is another release of 10.6.4 also marked as 18 April 2011 but different than the one available today in RT site.
I am saying that because I don't know if Ross Tech is uploading new versions of VCDS 10.6.4 just with new black listed serials and keeping the same date and version number.
Imagine this: I downloaded VCDS 10.6.4 a couple weeks ago before RT found out that there is another free dump so RT reupload the same VCDC 10.6.4 but with a new blacklist.
So to be sure I need to download today from RT 10.6.4 version and find out if it's working or not with 11.2 dump or compare HASHs.
This is not odd because I own two versions of VCDS 11.2 beta with different file sizes... I downloaded them in different time frames.
I again.
I download a couple minutes ago VCDS 10.6.4 from RT site and I compared HASHEs from the one I download today and the one I download a couple weeks ago.
Conclusion: both versions are the same.
So, you have your answer here
but keep in mind that this is not always true... As I said I own two versions of VCDS 11.2 and maybe version 1 works with 11.2 dump and version 2 doesn't.
KenshinPT
I have a non black list version VCDS 10.6.4 but today I dont can upload to FTP - now i am Village.
The day after tomorrow I am load it.
tereksaz
@KenshinPT
Can you upload somewhere both installers of VCDS 11.2 beta that you are say that are different HASHs?
Thank`s
Runasdata can do issue when using VCDS.
I did this before with 10.6.0 and I suppose now can be the same.
Both versions of VCDS 11.2 expire in 2011-05-31.
First of it it was realesed in february.
This Beta version has date limited.
If u wanna use this Beta version u need a modified version to remove the limitation.
This will be usefull.
I don't know why u need to use this beta version if there is a released one 10.6.4?
Good luck
Are you saying that even changing system date these beta versions won't work at all?
Thanks.
VCDS Beta 11.2 V1:
http://www.multiupload.com/EXZQUQHSU9
VCDS Beta 11.2 V2:
http://www.multiupload.com/29711SNRK0
VCDS Release 10.6.4
http://www.multiupload.com/D7W45AJDDD
I downloaded this version (10.6.4) a couple weeks ago but today I downloaded it again from RT site and HASH verification confirms that this version is the same as the one you can download from RT site - until today
Regards and good luck
