Page 124 of 854 FirstFirst ... 2474114119120121122123124125126127128129134174224624 ... LastLast
Results 1,846 to 1,860 of 12803
  1. #1846
    OK, i understud.
    In the archive with dumps for 11.2 exist vcds_ru[s].exe..maybe is only a loader..but for english too..
  2. #1847
    RF
    Quote Originally Posted by olegario View Post
    Take a look here www.Car2diag.ru
    Here the program working only with the cable lies. This cable doesn't work with other language versions. But the Russian and English version (changed) is in the collection. The program asks a special file (vdlicense.dat) that the program worked. This file depends from hard. The program won't work on other computer.
  3. #1848
    Jun 2011
    i need some info please :-)
    i have a chinese clone cable with 10.6.0 software in english...
    chip is FT232RL
    Software runs without problems so far.
    But i want a german version.
    After 12hours of reading this forum, i know i need another atmel dump, right ?
    A friend of me owns a cable with german software, and version 10.6.4.
    since i cant read the atmel chip without special hardware i want to ask you.
    if he gives me his serial number, is it possible to add it to a atmel dump and flash it to my controller ? so that i can use his software version ?
    do i need to flash another chip then the atmel ?
    hope someone can help me.
  4. #1849
    Jun 2011
    Hi looking for upgrade files for my chinese 912 cable (FT232RL) so that it can work with VCDS 10.6.4 -- is that possible?
  5. #1850
    Jun 2011
    i think this question is answered a few times here in the forum. anyway i think you need to flash the atmel chip.. and maybe your ft232rl
  6. #1851
    Quote Originally Posted by SunFlame View Post
    I think my cable might be broken. When i put in the cable and check the device id it says: VID_0409 but PID_0058. It is a 10.6.3 cable, and i think i broke it while trying 10.6.4 software. When i put in 10.6.4 cable in my laptop i get PID_FA26. So how can i repair the 10.6.3 cable? I try putting the PID_0058 into the rt-usb.inf, but windows says he cant find drivers for the cable. How should i proceed? open up the cable?
    Guys i know i sound like a total noob, because i am. I've read tutorial and guides for the older cables. But is this something i can do myself? I dont even have a programmer or special soldering tools. But i am "handy" and willing to learn. Its just, all this talk sounds like alien speak to me . Can someone point me into the right direction? Or should i just throw the cable in the trashbin?
  7. #1852
    Jun 2011
    @sunflame : so whats the prob with your cable ?
  8. #1853
    It no longer works with any software. I tried 10.6.3 10.6.4 and 11.2. The cable is designed to work with 10.6.3. But i broke my cable while trying 10.6.4. I made a mistake.
  9. #1854
    Jun 2011
    please plug in the cable and check if the driver is loaded correctly by looking into the device manager.
    perhaps your vid and pid has only be changed thats not a big problem at all...
  10. #1855
    Oct 2008
    On Earth
    M8
    Yes you did but all we do mistakes.
    So don't worry and don't be mad.
    Read carfully this huge thread and you'll see all you need.
    Including the step by step tutorial.
    Good luck
  11. #1856
    DK Veteran mishu_b's Avatar
    Land of Choice!
    let's start!
    1. first have a look into device manager with the interface plugged into USB port and see if your interface it is still seen by the PC as it was in the past. Ross-Tech-bla-bla-bla.
    2. check if your PC has a parallel port
    3. ask a friend for soldering tool.
    to be continued!
    atb
  12. #1857
    Ok. So i remove all old software + drivers. Fresh install vcds 10.63. In devicemanager it shows name: Ross-Tech HEX-USB. I am not sure if this is the correct name, i dont remember.
    However in the past it would find the driver itself. Now it wont even reconise the driver if i select it manually in device manager. I navigate to RT-USB.inf, but then it gives error: Cannot find driver for the hardware in this location.
    Thanks so much for your help
  13. #1858
    May 2011
    Brussels
    I have the same problem with my new cable.
    A chinesse clone who was working with 10.6.3.
    Inside Ft232RL
    The Product id has changed from FA24 to 6001.
    After that I used Mprog and I modify from SerialUSB back to Ross-Tech HEX-USB with 0403 & FA24
    But the cable still doesn't work, when the cable is plugged to computer only everything is Ok , when plugged to the car seems like interface isn't recognized as connected and the serial from the software is Unregistered/Unactivated but is the same as before.
    I have a solder, I have a parralel port + a parralel cable.
  14. #1859
    Oct 2008
    On Earth
    Guys
    When this tool isn't recognized and its driver is changed for very sure its licences was erased and you need to reprogramm its Atmega.
    Don't dream to much
    Ok if you use MProg you can reprogramm the FT232 to be recognized like a ross-tech driver VID_0403PID_FA20 but after that the interface will be recognized by the VCDS softwear and when you'll check if it Registred/Activated in the ABOT you'll see that it isn't.
    So what you have to do is to reprogramm Atmega162 with flash and dumps for this kind of tools and much more it is necessary to reprogramm GAL or ATF too
    Good luck
  15. #1860
    May 2011
    Brussels
