Page 127 of 854 FirstFirst ... 2777117122123124125126127128129130131132137177227627 ... LastLast
Results 1,891 to 1,905 of 12803
  1. #1891
    DK Veteran mishu_b's Avatar
    Land of Choice!
    @ magadam - I can not understand you.
    What do you exactly need?
    I want to support you but I do not know how in this moment!
    atb
  2. #1892
    RF
    Quote Originally Posted by mishu_b View Post
    atb
    I want to see datasheet "Programming GAL16V8"
  3. #1893
    If i understood ok, the PES "say" what programming voltage ant what pulse period is necesary for that gal device. And "say" too the type of gal device.
    When i try to write a PES from a .jed file, any group of hexa number tell to galblast some.
    But i think that the PES is necesary only if you use "erase all"...
    Because any device have PES...and programmer recognize the device from PES
  4. #1894
    RF
    If i understood ok, the PES "say" ...........
    I want to look at tables of dependence of parameters from PES. For example it. But it for ATF22V10. "Manufacturer ID for ATF" it is equivalent "Product Electronics Signature (PES) for GAL".
    It is necessary to me for GAL16V8.
  5. #1895
    maybe is usefull that?
    GAL programming algorithms
  6. #1896
    POLAND
    I'm reading my PES from galblast GAL16v8 Lattice for example maybe is useful
    VW Passat 1.9TDI Variant 1xxKM/3xxNm by YaCa
    *VCDS10.6.4*MPPS*GALLETTO1260*VAG-K+CAN2.5*VAGTACHO3.01*WinOLS 1.7*
  7. #1897
    RF
    These are parameters Galprog, it is not enough of them. You have datasheets from firms Lattice, National Semiconductors or STMicrosystems? Thanks that help me.
  8. #1898
    Land of Choice!
    be careful with GAL device it is very sensitive to power supply.
    http://www.latticesemi.com/lit/docs/...23f806c6877161
    atb
    what is this my friend?????
    atb
  9. #1899
    RF
    Excuse me for the bad English. I want to see "datasheet how to PROGRAM and what electrical signals" for GAL16V8. As these signals depend from PES.
  10. #1900
    Member ironderek's Avatar
    To everybody who has 10.64 dump.
    2 weeks ago I programmed my BL cable with 10.64 dump and everything worked perfect, but today when I tried perform full autoscan software stoped after scanned 2 or 3 modules, and cable become unregistered. So I programmed it again, and works fine scaning single modules but when I tried to do full autoscan, cable becomes unregistered and lose FTDI drivers. 2 weeks ago cable works perfect with autoscan and other functions but suddenly something change. Do you know what could be wrong? Do your programmed cables with 10.64 dumps works ok?
    Cheers.
  11. #1901
    Oct 2008
    On Earth
    Do you wanna mean that if you use your softwear now the tools serials it is erased?
    Do you have disable updates installed into your hosts?
    Maybe the ross-tech figure it out that this serial is clonned and it is blacklisted now.
    Even that om their web site it is stil 10.6.4 version
    But if it keeps its driver but it becomes Unregistred this is somethingelse.
    Please check the VID PID of the driver.
    Good luck
  12. #1902
    Yes the FTDI VID and PID is change so interface is no longer recognize as Ross Tech cable, and software becomes unregistered version.
    Like I said this cable works fine 2 weeks ago with orginal Ross Tech software but now something change. It could be that I didn't disable updates, I have to check it out.
    Thanks.
  13. #1903
    Oct 2008
    On Earth
    I suppose that now the serial is blacklisted.
    "We started to fight again" mates
    Good luck
  14. #1904
    I checked it and updates was disable I had added line 127.0.0.1 into C:WindowsSystem32driversetc folder, so what is wrong?
  15. #1905
    Oct 2008
    On Earth
    Not just the 127.0.0.1 it is not enoght
    here it is an uplication
    If it is against the lows I will erase it
