Page 129 of 854 FirstFirst ... 2979119124125126127128129130131132133134139179229629 ... LastLast
Results 1,921 to 1,935 of 12803
  1. #1921
    Top Poster infobadr's Avatar
    Nov 2008
    ALGERIA
    I have a problem with vag com 908 clone. When I plug the interface to USB slot it is normally detected as a Ross Tech interface. Then, I D ONT INSTALL DRIVERS , the interface is no more detected ( Windows notifies that USB device is faulty ).
    Thanks for any clues
  2. #1922
    spychu14's Avatar
    May 2011
    POLAND
    Quote Originally Posted by infobadr View Post
    Uninstall VCDS, use FTclean, clean registry, reprogram ftdi with proper dump and install again.
  3. #1923
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Default Atmega 162 and UPA
    Hello friends,
    Someone used the UPA USB "wonderful" to read and write the ATMEGA162, I see that file to reprogram it to work with version 10.6.4 is 46K, while reading the UPA can only read 16 ..... someone uses UPA to make this?
    BR, Fifas
  4. #1924
    Junior Member Carlos_'s Avatar
    PT
    Quote Originally Posted by petrodies View Post
    Hi all,
    I just bought a new chinesse clone 10.6.3 but instead I received an 11.0.2 clone but the cable doesn't work witn 11.0.2( says interface not found).
    I waiting news from the seller but if you have any other information( seems that beta 11.0.2 expired end May)
    I believe chip inside is BL/BM.
    Thanks a lot
    Try to roll back the date to january or something. I reprogramed a BL with the new dump, and when i tried to use on 11.2, it says interface not found, but then i tried to set the date at january and it worked like a charm
  5. #1925
    cniky's Avatar
    Quote Originally Posted by fifas2010 View Post
    Hello friends,
    BR, Fifas
    Yes, is possible.
    See , Atmega 162 have Flash memory & EEPROM , you have to program with UPA both of them separately, not work in "one shoot" both of them like other programmers.
    PFA.
  6. #1926
    Member ironderek's Avatar
    Anybody knows how to activated opening/closing windows from key on 2004 Passat using VCDS?
  7. #1927
    cniky's Avatar
    No possible on this model with VCDS , only with VDS_Pro.
  8. #1928
    May 2011
    Brussels
    You can find here a software( not vcds) but you need the old KKL cable(for 409.1 vag-com) or you can use software like VDS-PRO with a serial vag-com cable(for 311.2 vag-com)
    MOTORDIAG - autodiagnostika, VAG-COM , OBD , KWP2000 , OBD2 , CAN BUS diagnostika
  9. #1929
    Thanks, I have that software, but I don't have KKL cable any more
    I tought that I can do this with VCDS. Can VCDS do this on CAN cars?
  10. #1930
    Jan 2011
    Hi, I have small problem. I've got from friend of mine VCDS cable 10.60 BL based interface destroyed over internet updates. I programmed FTDI with .ept file, then programmed atmega with 100% working dump, but then after all of that cable is no problem recognize as Ross Tech interface, but when I do test interface on the car I've go the message Iteface not found? Why is like that? Do I have to programm GAL as well, or is something different wrong? When I take for example working 704 BL cable and do upgrade with to same dump everything works perfect. Why the damage cable doesn't work?
  11. #1931
    cniky's Avatar
    "CAN cars" have already this function in place, with VCDS you can activate future "auto roll up" on them.
  12. #1932
    DK Veteran manocao's Avatar
  13. #1933
    Oct 2008
    On Earth
    It is VCDS 11.2 interface boght it from China and resseled in Europe on ebay.
    Just like this.
    I suppose that is a non repramming one because Chinese don't make newer version of VCDS with FT232BL, just with FT232RL
    Good luck
  14. #1934
    Sep 2010
    in the midst of war
    Default Atmega 162 with UPA
    Quote Originally Posted by cniky View Post
    Yes, is possible.
    PFA.
    Thank you, but dump that i have to program Atmega have 46k, do you have a dump to program with upa flash memory and eeprom...
    BR , Fifas
  15. #1935
    Oct 2008
    On Earth
    Split that dump into flash and eeprom and then use it
    Good luck
