Page 130 of 854 FirstFirst ... 3080120125126127128129130131132133134135140180230630 ... LastLast
Results 1,936 to 1,950 of 12803
  1. #1936
    May 2011
    Brussels
    Quote Originally Posted by mattydr67 View Post
    It is VCDS 11.2 interface boght it from China and resseled in Europe on ebay.
    Just like this.
    I suppose that is a non repramming one because Chinese don't make newer version of VCDS with FT232BL, just with FT232RL
    Good luck
    I got one this week, bought in China ( 2-3 weeks for delivery) and it have BL inside ans works with 10.6.4 from ROSS-Tech.
    I expected a 10.6.3 and instead they send me a 11.0.2 clone.
    @spychu14 Thanks, it works with original 10.6.4
    Carlos_ Finally I tried with 10.6.4 and works .
    Thanks anyway
  2. #1937
    Split that dump into flash and eeprom and then use it
    Good luck
    With PonyProg....
  3. #1938
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by fifas2010 View Post
    Thank you, but dump that i have to program Atmega have 46k, do you have a dump to program with upa flash memory and eeprom...
    BR , Fifas
    With PonyProg....
    Open your device file in ponyprog
    Save eeprom as....
    Save Flash as...
    Done..u have now the 2 required files u need
  4. #1939
    Jun 2011
    I'm looking VCDS scheme with RL and BL chip. I want to compare them and replace your RL to BL.
    (sorry for my English, I use google translator)
  5. #1940
    RF
    With PonyProg....
    Look this.
    http://www.digital-kaos.co.uk/forums...ml#post1133836
  6. #1941
    Pitesti,Romania
    i have vcds 812.4 china clone . it has "stc 12c1052" - protection mcu , ft232BL
    i want to update with 11.2 dump .
    it is enough to flash the atmega only? or i have to flash the GAL too and remove the protection chip etc?
    i think the protection MCU only flashes the ftdi eeprom each power on. it has FA20 pid. will this work with 11.2 ?
  7. #1942
    Hi latest vcds dump?
  8. #1943
    Can sombady sendmi original vcds 10.6.2 installer ? original!!!!
  9. #1944
    Member mecaniquito's Avatar
    Oct 2010
    Default caterpillar sis 2009B
    hello to all of the forum I have the sis caterpillar kg 2009b and want to share the activation key but I want all the published inthe discharge to this system would greatly appreciate it thanks
  10. #1945
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Default Upa and at162 lock bits
    Quote Originally Posted by rsibiza View Post
    Save eeprom as....
    Save Flash as...
    Tank you BIG " RSIBIZA"
    I make what you said, now i have 2 files, flash and eeprom
    But about lock bits ?? can you hekp me
    See the dumps,
    BR,Fifas
  11. #1946
    Maartinj's Avatar
    Nov 2010
    Did anybody know how to translate VCDS software ?
  12. #1947
    POLAND
    Default Maartinj
    Quote Originally Posted by Maartinj View Post
    Translate is not so easy becouse you must UNPROTECT VAGCOM protect by pc guard) and after this if You want You can edit VCDS by program for example RESHACk.
    In new program like VCDS 908 or newer be caerful becouse it sart two programs:
    VCDS.exe
    and q.exe
    So i think that You must edit this two programs.
  13. #1948
    Quote Originally Posted by djcristi View Post
    Remove STC (uC), R50 and T5 (in fact is an CI, "reset-er")
    Reflash atmega and FT232BM.ept
  14. #1949
    Pitesti,Romania
    can you take me how should i set the fuses? i am programing with extreme burner / khazama , with usbasp isp programmer.
    do i have to use a new atmega162 ? how can i find if SPIEN is locked?
  15. #1950
    For eXtremeburner from left to right:
    CD, DC, F9, CC, FFFFFF56
    With that CC the Atmega is locked to read..
    Thats hex numbers are the hex of that bin of ponyprog..(enabled/disabled bits)
    Of course, "enable" to write all fields...
    For Khazama ..i have the setting but..i never use khazama. Only "first time" when with the setting from dk my atmega was locked.. i unlocked..with atmega doctor...
    About ypur name, i think you can write me in RO on the private???because my english is bad..(
