Page 134 of 854 FirstFirst ... 3484124129130131132133134135136137138139144184234634 ... LastLast
Results 1,996 to 2,010 of 12803
  1. #1996
    Quote Originally Posted by mattydr67 View Post
    marian check this out
    Good luck
    Thanks! Now it`s working. I already seen these configuration bits in the upgrade tutorial, and I thought that checked means 1 and unchecked means 0, but on the bottom it says that it is just the other way .
    Thank you again and !
  2. #1997
    Jun 2011
    Hi does anyone know where i can by a interface with a BL or BM chip ? but please not to expensive :-)
  3. #1998
    Pitesti,Romania
    1.84 dump works only with english version of software?
  4. #1999
    makura's Avatar
    Default VAG K+CAN 3.6 dump
    Hi guys
    I was playing around with mprog and my vag k+can interface now it's not working,i think i erased the dump file in it.
    Does any one a good dump for this unit,it's a version 3.6 from china(cloan)
  5. #2000
    Oct 2008
    On Earth
    Hey mate
    I haven't seen this before but you got a thread here for this.
    http://www.digital-kaos.co.uk/forums...p-files-61706/
    Check this out maybe it'll be useful for you.
    Or maybe someone who hase ept file for you to share it.
    If you played just with MProg you have no big damages.
    Good luck
  6. #2001
    ROTIM
    For Makura
    If your interface is with ftdi232RL then look here EPT
  7. #2002
    spychu14's Avatar
    May 2011
    POLAND
    Anyone tested how 11.2 works with RL interface and loader ??
    VAG
  8. #2003
    makura's Avatar
    Quote Originally Posted by flavitm View Post
    For Makura
    Thanks m8,so all i have to do is load this in to my interface using MPROG and bingo,right?
  9. #2004
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by makura View Post
    not really - this is only the FTDI "dump" - if your tool has inside also one uC that you will need to reprogram too the uC.
    atb
  10. #2005
    Harrycz44
    Guest
    Hello
    I have VCSD clone with 11.2.0 en beta version, can I use 10.6.1 cz version? or i death interface? Thanks for help me
  11. #2006
    Quote Originally Posted by Harrycz44 View Post
    Hello
    They are different languages, so i guess it will not work. If 10.6.1 cz is older than 11.2.0 en beta, then it shouldn't kill your interface.
  12. #2007
    Land of Choice!
    if you are lucky your tool will work also with cz version, but for sure your tool will not be dead after this operation even your tool will not work cz version.
    atb
  13. #2008
    Harrycz44
    Guest
    I tested it and work..
  14. #2009
    Oct 2008
    On Earth
    Take a look and tell me if it is full resgistred/activated.
    just because the inetrface it was erased because this it hasn't this softwear in blacklist but it is not a serial for that language just for englesh.
    I tested it for romanian laguage with 10.6.4 , it's working I mean the interface it wasn't erased but the softwear remain unregistred. It didn't become Full registered/Activated.
    Good luck
  15. #2010
    Aug 2010
    Does anybody have experience with the Digiflasher Pro V1250?
    Recommended?
