Hello there, i was hoping someone could guide me.
Seems like I killed my Cable, I plugged into VCDS 10.6.4 while on the internet, It's a VAG106 Dual K&CAN <-> USB
FT232R- based.
Trying with VCDS 10.6 will end up with a Timeout Error.
Use seach in DK, thread about restoring firmware in old versions like 704.
Probbably PID,VID is not anymore ok, and you don't see you cable in device manager as known device.
Edit driver .inf to access FTDI. and after probbably u need to reprogam atmega as well.
br
fine for you that you solve the issue.
atb
Hi ,
where to find a VCDS scheme for Chinese clone with security chip .
Thankyou
Costas
I have a dead chinese 10.6 with security chip. Is it enough to desolder the chip or any additional modification needed to upgrade to 11.2?
i am running vcds 11.2 on an interface flashed with 1.84 dump available on the net. if i test interface under windows 7 , i get serial hex7386-014155-50275a-044127-bjhahh-5153 , fully registered.
if i test the interface under windows xp sp3 running on virtual machine Vmware , i get the same serial but unregistered / unauth .
i mention that the virtual machine has no internet access, so it can get the banned serial .
what do you think is the problem?
tested also with windows 7 xp mode , working , so vmware is the only problem...
Solved !!! after i push test the second time, it shows Fully Registered in vmware too. don't know why i have to test twice, but it works.
only in vmware i have to press test twice, on native xp/win7 , i have to press only once.
