Page 13 of 854 FirstFirst ... 3891011121314151617182363113513 ... LastLast
Results 181 to 195 of 12803
  1. #181
    Quote Originally Posted by bibkare View Post
    Try to remove only stc chip then reflash atmega, after that test autoscan
    This is the correct solution. I have seen that version of clone before, it has the STC chip but does not have the transistor installed. You can see on the PCB where it would go.
    So as stated before remove the STC chip, reflash atmega and you'll be good to go.
  2. #182
    xoom's Avatar
    Ylakiai
    Hmm.. for VCDS-Lite is no needed modern interface.. just simple K line adapter..
  3. #183
    hi,is it possiblle to update china 704 version to vcds 908 or newer with reflashing atmega and 93c46?thanks
  4. #184
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by antibisic View Post
    Pa procitaj malo od pocetka sve je objasnjeno
    Read all posts
  5. #185
    don,t see any post about upgrade 704 on 908 or 912 just 805 on new.I am asking because don,t know about hardware is it different?Thanks
  6. #186
    Can I upgrade my interface 908 (FT232BM+93c46+ATmega162) whith a 10.6 dump?
  7. #187
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    Yes, you can.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  8. #188
    May 2009
    Default wanted vcds 10.61 swedish
    loking for passvord to login on Svenska Vag-Com - VCDS - B?sta diagnosverktyget f?r VW, Audi, Seat, Skoda & Bentley and get swedish vag vcds 10.61...any????
  9. #189
    Quote Originally Posted by kls123 View Post
    OK, thank you.
    I removed STC. The interface still works. Let`s see how long
  10. #190
    Default The same as VCDS?
  11. #191
    are there any dumps for 10.61 so i can upgrade my 908 to read my newer modules??
  12. #192
    Jun 2009
    Only for 10.6
  13. #193
    Member ironderek's Avatar
    Does VCDS 908/912 works on Windows 7 64bit OS? I installed software but when I connected interface into USB port computer said no drivers detected. I found on net some drivers but still doesn't work with window 7 64bit, I installed it on Vista 64bit no problem, but on 7 64bit I couldn't make it work. Can somebody help me with this matter?
  14. #194
    Junior Member ghicicine's Avatar
    Romania-Cluj
    Quote Originally Posted by ipejasinovic View Post
    Only for 10.6
    Are you so kind to tell us where we can find for free the 10.6 dump?Thank you.
  15. #195
    dyc's Avatar
    "Is this the same as VCDS?
    VAG CAN PROFESSIONAL - DIAGNOSTICS SYSTEM :: vag-tech.eu"
    no its a polish project im using it becouse of ocf (one click functions) but is still more to do
