So did you said that you read the dump from your tool and this one work with VCDS 11.3?
Good luck
Good luck
@samiko
Erease you message from your PM to be able to revive messeges.
Good luck
Here it is
Good luck
VCDS12.12.4,Clip,LexiaC,Delphi,MPPS,FGTech2,FVDI,B eePROG
thanks for the reply
you have some other flash 1.83?
You can give it to me, with the your other would then work could
This is schematic with FT232B. Look at the wires/connections between FT232 and GAL, GAL-ATMEGA, MCP2515-ATMEGA.
This version work with original 10.6.4 soft and modified 11.2 (modified because of expire period). Flash and eeprom is the same uploaded on rutraker.
Your schematic must be modified MINIMUM like in Aminebot tutorial (except unsolder STC if you haven't), reprogram atmega, gal and ft232 with correspond versions and use MODIFIED soft for RL.
MAYBE (i not probe yet) if you make the modified like in LittleTOXA photos you can use original soft.
But...autoupdate i don't think so...in the newer version vcds your serial is blacklisted...if use public dump
if you use your dump from an original cable how you read dump?
Try read from VCDS cable original "FUSE AND SECURITY BITS". Is sure posible. Next, read the same from clone. Must be identicaly.
