I did not have time to solve
when you find time so doing I will draw Schematic
yes 93Cx6 memory is to the other side
Here is a photo the other side
VCDS12.12.4,Clip,LexiaC,Delphi,MPPS,FGTech2,FVDI,B eePROG
programmer "FA series" write in datasheet or CSI10...see page no. 538..
wtf is that programmer?
vcds 11.3 china version work with new version of vcds 11.8![]()
M8 iit is normal because no 11.3 dumps showed up.
And the serial for 11.3 it is not banned. That's why works with 11.8
Good luck
china 11.30 work only few mins.
with 11.80 work less
serial in china 11.30 is banned from 11.20 ...
just try complete autoscan, long codding and etc -> "no response from controller"
Serial in 11.2 works 5 times with 11.3 maybe with 11.8 works less how you said.
But I suppose he talking about 11.3 serials.
Let's him to explain.
Good luck
P.S> What I think is that ross-tech banned the 11.3 serials in 11.8 for sure
I have seen such cable.
The serial number is the same as in 11.20 and was posted here.
They say that the problems are in 11.30
But everything works at 100% with good clone.
Help please to understand what is happening.
I've got my own license. Took a clone for 10.6.2 (RL).
If I program 10.6.0 cables (RL too) - everything goes fine, it updates, correctly works etc.
If I program this 10.6.2 cable (RL, scheme visually the same!) - it works just fine, but can't update until I program it with firmware from BM cable (11.3 chineese).
What have changed in China so that this cable thinks that it's BM-based for updates ?
vcds 11.8 work with china clone 11.3
OK, delete the d1,d2,d3 bin files from VCDS folder and repeat test
If appear again d1,d2,d3 and appear FULY REGISTERED after the FIRST test, is ok.
Repeat test with delete d123 after 2-3 days. If is again fully registered, is ok.
How many times did you tried?
Dumps for 112. works with 11.3 just 5 times. Then the serial will never work and when you'll try to come back to previos version the eeprom will be erased, from what I know.
If it's working many times keep the 11.8 version because will be usefull in the futhure.
Good luck
the serial is already blacklisted from 11.30
just lamer do not stop to dreaming and posting
Chinese only make self recovering interface, but is fully non usable for versions after 11.20.
yes
i tryed and did not work ok
lasted version wich work is 11.2
sory for my entusiasm
