Page 147 of 854 FirstFirst ... 4797137142143144145146147148149150151152157197247647 ... LastLast
Results 2,191 to 2,205 of 12803
  1. #2191
    Jan 2011
    Hi, can somebody help me?
    I'm looking for 2 VCDS chinese installers 10.60 and 10.62 for chinese cable based on FT232RL
    Thank you.
  2. #2192
    Oct 2008
    On Earth
    Quote Originally Posted by magadan View Post
    To delete - to check up with MProg - to solder into place
    Can you expalin with more words - please
    Good luck
  3. #2193
    RF
    Quote Originally Posted by mattydr67 View Post
    I wanted to tell that chip STC can block record and reading in EEPROM. Therefore it is necessary to delete chip STC. To connect a cable with USB. To make record in EEPROM by means of MProg. To check up, how has transited record. If it is bad to solder a chip into place. And then to replace EEPROM.
    Sorry bad English.
  4. #2194
    Oct 2008
    On Earth
    Sorry bad English.
    I know this but you said delete I suppos that you wanna say unsolder forever the STC from PCB.
    Then reflash the FTDI.
    Me and liviu_diaconu didn't understand what you mean with "delete"
    We suppose you said that:
    - unsolder the STC then reflash FTDI and then solder the STC back.
    Good luck
  5. #2195
    But..why resolder STC? i think is more better unsolder STC, reflash atmega, FTDI, GAL, rerouting the "links"
    ATMEGA-MCP2515, ATMEGA - GAL, GAL-FTDI.
    And i understud that in STC (STC is u-controler, like atmega) is registered serial or dump and if atmega dump is erased from newer VCDS (because of blacklist), if unplug and replug vcds to 12V the dump is reloaded in atmega from STC (but the older dump). If is wrong, sorry.
    If is real, stc is ok if don't want to use a newer version of VCDS.
  6. #2196
    Oct 2008
    On Earth
    Guys
    In a tool with RL
    I reflashed GAL, ATmega and FTDI
    I unsolder the components like in the Tutorial made by our friend Aminebot and I made new soldering as well ( the tool is the same as in the Tutorial )
    When I did the Test the Led was red and then it started to blinking.
    And the message was Time Out
    The question is: What will can be? The GAL wrong flashed ( I tested this and all was ok )
    I tryed to make modification like into the rutraker.org, same thing
    Any ideea will be usefull
    Good luck
  7. #2197
    DK Veteran bibkare's Avatar
    B & H
    Guys
    In a tool with RL
    Good luck
    If i remember correctly in this tutorial aminebot used english 908.0 version and crack (3 files which needed to be replaced after installation), maybe you should try this version, i mean maybe it's software, you did hardware mod OK
  8. #2198
    Oct 2008
    On Earth
    Hi my friend
    The problem is that when I plug the tool to the 12V the LED first become red and the it will blinking
    And I use the dumps from that tutorial.
    Exception are the Atemga dumps ( I use the 11.2 dumps )
    But this is not important
    I suppose that it will the GAL issue but how I said I wanna hear anothers ideas. This will be helpfull to think
    Good luck
  9. #2199
    check fuse and lock bits.
    also reprogram GAL
  10. #2200
    RF
    Guys
    In a tool with RL
    If you have "RL" check up a cable with the version of the program 704 or more low. If change is not, check up GAL. I give equivalent the circuit for damp from AGK.
  11. #2201
    Oct 2008
    On Earth
    Atmega it is ok just I will try to reprogramm GAL again
    Good luck
  12. #2202
    H? mate , I buy a VAG-com 10.6.2 china with ( USB DIRECT ROSS TECH ) but not work , software is bad , fake , bug .
    Some idea ?
  13. #2203
    Oct 2008
    On Earth
    Quote Originally Posted by jo?o antonio View Post
    Some idea ?
    You need to reflash your tool with other version
    Good luck
  14. #2204
    Good luck
    Ok mate , but , any software modified for the VAG-com 10.6.2 ?
    The Driver is USB-ROSS TECH , not BL , not RL . !!!!!!!!
    only software I need.
    Thanks.
  15. #2205
    Oct 2008
    On Earth
    Quote Originally Posted by jo***1075;o antonio View Post
    Thanks.
    Other one that 10.6.2
    Good luck
