Hi Guys!
I need some help to repair atmega162. After i was try to write new flash, maybe something crashed in atmega, because i can not connect to it. I think the internal clk switched to external mode, but i do not know how to solve this problem.
Have you any idea what can i do?
Thank You!!
Peter
Good LuckToday almost finished one more
can't get MCP2515 can controller
Hy Guys,
please I need a little bit Help
im from Germany therefore my bad English.
Yesterday Im unfortunately destroy my English VCDS 908 clone with the English Version
Of VCDs 10.6 . Now Window detect the cable as unknown device, I want to fix the cable
and read many topics here and from other sites about fixing damage cable.
Now I hope anybody can help me a little bit, I need a Dump 908 ore (can I use a dump from 912?) and a prog to flash it (I think I have to solder the atmeg162 to flash it with LPT prog is this right?) Have anybody a description?
many thanks
Hi so my FTDI is FT232RL I have download a 908 Dump from this Page and now i want to flash it abaut LPT1 I use the description as gudline
(Tutorial , VCDS 805 programming and upgrading) Ok ?
In this desciption the dump is a .bin File my dumps are a .hex files is this correct?
when this is done, what is the next step?
I do not Unterstand "ftdi eeprom also you have dumps here (FT232RL OR FT232BL) then you are good to go"
What i have to do? is the next step to follow the tutorial
( Final solution for Chinese VAGCOM interfaces with protection chip and FT232R) with which program and Hardware i flash the ftdi?
Please help me
Thank you very very much
greetling Nemesiz12
OK, so i flashed my Atmega and now i am having some issues. should i have removed the STC and other parts before using it as it now does not work?
do you have to add the 3 wires as per the guide or just remove said components before use?
i am guessing i will have to reflash 1.83 and arash 908?
thanks in advance
How you have flash your Atmega?
You have use the description(Tutorial , VCDS 805 programming and upgrading) and which dump you use?
For interface with FT232RL you have solution here http://www.digital-kaos.co.uk/forums...ft232r-160237/ for this interface use ftdi eeprom for 232rl from here http://www.digital-kaos.co.uk/forums...tml#post816515 also for ft232rl you must use ftprog (no mprog) and rename extension from .ept to .xml
If your interface has ft232bl then you only need to remove stc chip, transistor and resistor before flashing atmega and after flash ftdi eeprom with mprog (erase first than write). Anyway, it is much better to have interface with ft232bl, recently i upgraded interface ver. 607 to 912 without any problem.
best regards
P.S. again and again dump ver. 908 http://www.digital-kaos.co.uk/forums...tml#post747646 People you need to read a lot more
hy
my problem is the flash order
there are two chips the Atmega and the TF232RL in the cable ?
an i have to flash both ore not?
than i flash the Atmega with the 908 Dump therefore I use "Tutorial , VCDS 805 programming and upgrading " i solder the cable and resistors like in this Tutorial is this correct?
I Have download this dump from arash but there are two fils in the rar file in the tutorial the extension is a .bin
file and only one file to flash but in the rar file are two .hex files a eprom.hex and a flash.hex <- I need both and what do with this files?
OK than when its done, i flash the TF232RL, but how i flash the TF232RL with which hardware? can i use the same
how i flash the Atmega?
Thank You for your help
Flash order: first write ftdi eeprom with appropriate dump for ft232rl or bl, use mprog or ftprog acordingly. For this you don't need any soldering, just connect interface to usb port (all this is very well explained in tutorial)
second: connect wires on your atmega like in tutorial and supply power to interface, open ponyprog choose first flash file (extension .hex) then choose eeprom file (also .hex extension) program it. Forget about .bin file, use arash dump with two files
Hit thanks button if this helps
andrei88 (30th March, 2017), ilico (13th January, 2016), markudariva (7th October, 2018), miralem (16th March, 2016), ni88l3r (7th January, 2017), Novica (24th March, 2019), Tor999 (16th June, 2022), zZarZiLLoSs (25th May, 2020)
Hi Thank you very much for your help.
you say use the tutorial to flash the ft232rl where is this tutorial i search for it but i do not found it.
I only have a Tutorial to flash the Atmega.
Furthermore when i connect the cable to the usb port windows 7 tell me unknown device and in the device manager
a exclamation point appears. You say the ft232rl become flasht with the USB port but windows do not recognise the cable correct. The flash will function?
