Page 153 of 854 FirstFirst ... 53103143148149150151152153154155156157158163203253653 ... LastLast
Results 2,281 to 2,295 of 12803
  1. #2281
    miha99's Avatar
    EU
    Did you uninsatall old version of soft and drivers?
  2. #2282
    DK Veteran mishu_b's Avatar
    Land of Choice!
    try with drivers from FTDI home page
    or try this!
    all the best
  3. The Following User Says Thank You to mishu_b For This Useful Post:
    ilico (20th January, 2016)
  4. #2283
    problem solved, thanks to mattydr67
  5. #2284
    Sep 2010
    Hi everyone!
    Will my tool work with 10.6.4. dumps?
    It oryginally comes with untouched Ross-tech 504-UD software and still works
    Maybe I'm lucky and S/N in this tool is not longer blaclisted?
  6. #2285
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by noogi View Post
    Hi everyone!
    Yes, your tool will work with any working dumps!
    About the: "Maybe I'm lucky and S/N in this tool is not longer blaclisted?" I have so say:
    ...Keep dreaming
    But it's nice to have a colletion of old working dumps! Try reading the ATMEGA and post here the dump and VCDS soft.
    Did it help? Push Thanks below
  7. #2286
    Oct 2008
    On Earth
    I suppose that the Atmega it is protected but he can try and we can check.
    Good luck
  8. #2287
    Sep 2010
    I will try
  9. #2288
    Sep 2010
    Didn't worked
    I suppose, that programmer should be recognized by software even without connected atmega chip, but my programmer is visible only in AVR Studio and not connecting do atmega. I also use AVR Dude with GUI, but it not recognized connected chip.
    So I have to wait for another programmer (usbasp) which I ordered yesterday.
    regards
  10. #2289
    Land of Choice!
    use PonyProg - to reflash the uC.
    it is the cheapest solution!
    atb
  11. #2290
    Sep 2010
    Not every computer now has LPT port
  12. #2291
    Correct, the problem is what is cheapest: AVR USB programmer or a PCMCIA/LPT device?
    And, of course, the LPT is worn.
  13. #2292
    PT
    You can get an USBasp for 3.99 USD including shipping
    The money you'll spent on a LPT programmer made by you is about the same as the USBasp from ebay...
    I have both and believe me... USBasp is great!
    Of course LPT programmer has it's advantages, for example, works on ponyprog and USBasp won't... but hey, you have other good quality software burners.
    And yes!!!!! If you want to upgrade your USBasp you need another USBasp or a LPT programmer
    Check on ebay.com and you'll be surprised
    USBASP USBISP AVR Programmer USB ATMEGA8 ATMEGA128 | eBay
  14. #2293
    Sep 2010
    Programmer thats I already have didn't work for me - it's USB AVR ISP II STK500v2, so I ordered another one - this time USBasp.
    I hope I didn't broke my tool trying to make connection with my programmer.
    There is a very useful programing software with build in fuse calculator - http://atnel.pl/mkAVRCalculator_build_57.rar - it has an English interface too (you have to delete folder \mkAVRCalculator_build_57\locale\ after unpack).
    Another thing I observed - there is no certain infos about lock bits (fuse bits are in many places almost the same):
    in hex:
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
    and from another post:
    LOW: CD
    HIGH: DC
    EXT F9
    LOCK: CC
    and from rsibiza extremeburner manual:
    Low fuse: CD
    High fuse: 9C
    Extended fuse: F9
    Lock fuse: CF
    which set is OK?
    regards
  15. #2294
    Land of Choice!
    fully agree - together with Khazama or eXtreme Burner perfect match!
    atb
  16. #2295
    PT
    in hex:
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
    LOW: CD
    HIGH: DC
    EXT F9
    LOCK: CC
    Low fuse: CD
    High fuse: 9C
    Extended fuse: F9
    Lock fuse: CF
    which set is OK?
    I use the second! But I also used the 1st by mistake and it also worked ^^!
    The third I never used.
    Good luck
