Page 155 of 854 FirstFirst ... 55105145150151152153154155156157158159160165205255655 ... LastLast
Results 2,311 to 2,325 of 12803
  1. #2311
    Sep 2010
    if the author write you about "CC seting"..tell us please..
    The answer from the author (sorry for the ungrammatical translation):
    "If anyone wants to save the value of FF lockbits it means that he does not know what this is, unfortunately, because it looks that someone wants to delete fusebits and this can not be done if they are set - unless you delete the entire processor - this operation deletes only lickbits
    and the value of CC? is a value from space
    I propose to use the tab in the program LockBity MkAvrCalculator - where you can clearly choose what we want to set security
    And typing manually in the form of HEX lockbit?s - this must first be familiar with and know well the same AVRDUDE to know what's going on
    generally the case that AVRDUDE never sees the value of FF but 3F, since only the two oldest bits are always 0 for him
    So it seems that everything is in perfect order
    and how someone wants to save himself some value and then let it check whether the security is enabled - after all it is easy to check."
  2. #2312
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by Eamonahmed View Post
    I have Vcds 11.2 from china ,Before it is working But suddenly
    doesn't recognize usb driver
    I have try like this but doesn't detects Driver
    Ross-Tech: VCDS: USB Driver Installation for Windows XP
    Q: what driver required now the interface? (USB universal converter or ROSS-what ever)
    according to this answer we can guide you forward!
    atb
  3. #2313
    Sep 2010
    It is possible to read fusebits with extremeburner?
    I double check connection, external powered the interface and still had no communication with the chip:
    what is wrong?!
    How to check communication?
    Maybe only in writing mode will be that possible?
    regards.
  4. #2314
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by noogi View Post
    what is wrong?!
    regards.
    That's seems to be a miss or wrong connection problem...
    OR... maybe ATMEGA has SPIEN disable.
    If so, you need a HVPP - High Voltage Parallel Programmer.
    Good luck and regards
    Did it help? Push Thanks below
  5. #2315
    dimitar's Avatar
    Quote Originally Posted by KenshinPT View Post
    Or an external oscilator instead of a crystal
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  6. #2316
    Land of Choice!
    try with khazama - also I have sometimes problems with eXtremm --
    atb
  7. #2317
    near Strzyzow
    The better is UPA USP.
  8. #2318
    DK Veteran VTS_Tibi's Avatar
    Hi guys! I have pretty much the same problem as Eamonahmed.
    I have a VCDS interface with "VAG 10.6" written on it. It has been working OK for a while! Once I tried to use it on a car, and the computer did not recognize it.
    Tried to uninstall the drivers, but still no good. Tried to install it on an other computer but the problem is the same.
    How could I solve this problem?
  9. #2319
    PT
    Quote Originally Posted by VTS_Tibi View Post
    Reflash ATMEGA and FTDI.
  10. #2320
    Okay Could you please show me what dumps should I load to those?
  11. #2321
    1 "If anyone wants to save the value of FF lockbits it means that he does not know what this is, unfortunately, because it looks that someone wants to delete fusebits and this can not be done if they are set - unless you delete the entire processor - this operation deletes only lickbits
    2 and the value of CC? is a value from space
    Tell him that:
    1. I never say that's possible to set HH from CC with uC content preserved. No, you must delete content, write and set fusebits and lockbits..
    Like functionality FF or CC (or 0C in the case mkAVR) is the same.
    2. Look on the attachment: on first row are lockbits and on second are EXTENDED, for ATMEGA162.
    In mkAVR.. If i set only bodlevel0 and bodlevel1, appear F9, or if i set F9 manually appear like in my attachment, only bodlevel1 and bodlevel0 enabled, so, ALL bits, include "grayed" are 1, ok? because F9 (h) = 11111001, ok? So, he consider inexistent grayed bits as 1-disabled, OK?
    If is correct, on my atachment appear on first line 11 (grayed)001100, so, CC(h).
    That's translate from ponyprog and work verry fine in eXtremeBurner.
    In mkAVR he consider firs two bits "not exist" (but i think must consider "disabled" too, like in "extended case") next two enabled so 00 and last 4 1100, in this case is 0C.
  12. #2322
    Top Poster + mladen76's Avatar
    By the see
    First try yust reflash ftdi whit Mprog.
    If you chip is BL I am ataching file to reflash.
  13. #2323
    ovi_dk's Avatar
    On board
    Default Hi
    Hi all,have sombode vcds 11.2 in Romanian language,If yes please share with me,mi cable its 106 vcds clone update to 11.2.
    Thank you in advance Guys
    If u have the answer say Thank You!!
  14. #2324
    Oct 2008
    On Earth
    Quote Originally Posted by ovi_dk View Post
    ovi the last version in romanian is VCDS 10.6.4-Roj
    And for this you need dumps in Romanian.
    English dumps don't work.
    Good luck
  15. #2325
    ovi_dk's Avatar
    On board
    Default mattydr67 DK Veteran
    Thank you very much for informations and quik answer,now i know
    Anyway if sobode have the VCDS 10.6.4-Roj please share with me thanx
    Best Regards
