Page 157 of 854 FirstFirst ... 57107147152153154155156157158159160161162167207257657 ... LastLast
Results 2,341 to 2,355 of 12803
  1. #2341
    Pitesti,Romania
    most china clone interfaces have protection ic, that will rewrite ftdi-eeprom content & atmega-eeprom content on every power up. so these cables cannot be damaged
  2. #2342
    DK Veteran VTS_Tibi's Avatar
    I've treid to program the Atmega 162 with UPA, but I have a problem.
    I've followed this guide from rsibiza:
    "When using original UPAUSB there is a folder how to connect..wire up between upa and atmega...
    U need an DB9 connector to solder some 6 wires as described in the folder i mentioned...for ATMEGA162
    Best is powering up the atmega by upa also,no external supply...
    Need first read fusebits from working one...if need,i can post how they should be...
    *Erase flash erase eprom
    *Open first eprom hex,close fusebits select
    Atmega162 eeprom write
    *Open flash hex,close fusebits select
    Atmega162 flash write
    Disconnect BD9 connector from upa,and power up by 12V the interface...check if led turns to green...Done
    At the end, the LED lit up green, so all seemed good. But still, VCDS says: "Cable not found error -1"
    And when trying to read the Atmega with UPA I only get 000000 s.... (this may not be a problem), but eventhough I've programmed the fuse/lock bits, when reading them out, all says "false".
  3. #2343
    try program fusebits (CD, DC, F9) but not lockbits..
    Lockbits = FF
    You'll can read the atmega..
    If after test you read some content like the flash and eeprom "dumps"..and fusebits are CD,DC,F9..the problem is in another part of VCDS... In device manager appear like Rosstech HEX+USB? Or appear like Rosstech DirectUSB?
    If "direct usb"...is with RL and the procedure is different.
    Look inside your interface, maybe must unsolder STC, reseter (or diode), R..
    Can you upload photos with inside of VCSD? both sides of PCB.. But photos with good resolution.
  4. #2344
    It has the FT232BL, and it shows up as "ROSS TECH HEX or KEY USB interface"
    Will check what you wrote about the fusebits, if that doesn't help I'll upload a pic of the inteface
  5. #2345
    DK Veteran mishu_b's Avatar
    Land of Choice!
    nobody solved the issue related the VCDS with NEC uc?
    atb
  6. #2346
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by VTS_Tibi View Post
    For Rl based usbdriver you need also rewrite atf16v and make some more changes..see for 10.6 crappy interface mod
  7. #2347
    Look inside VCDS. Exist that STC? You must unsolder..3 components..
  8. #2348
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Hi, i have problem... Please somebody should dump Mprog (FT232BL) for 11.8 EN VCDS beta?
  9. #2349
    Oct 2008
    On Earth
    Quote Originally Posted by xanubysx View Post
    Hi, i have problem... Please somebody should dump Mprog for 11.8 EN VCDS?
    MProg ept file for any VCDS version is the same is the same.
    Here it is the ept file for VCDS tools ( no metter what version it is )
    Maybe you need more then this ( Atmega eeprom dump )
    Good luck
  10. #2350
    Quote Originally Posted by rsibiza View Post
    ATF16V? Could you please tell me what should I do?
    Here's my interface btw.:
    Tried to program it with PonyProg today, but it says "device not responding"
  11. #2351
    Land of Choice!
    your interface is with NEC uc not with Atmega.
    how did you programmed this uC? and with which dump?
    atb
  12. #2352
    Oct 2008
    On Earth
    Quote Originally Posted by mishu_b View Post
    atb
    Misu don't you see that he said that he couldn't because it is NEC and he tried with PonyProg as for Atmega.
    VTS_Tibi said: Tried to program it with PonyProg today, but it says "device not responding"
    No dump for Nec and it is a chinese thing, I suppose it will not show up.
    Good luck
  13. #2353
    atb
    How could you tell it's NEC?
  14. #2354
    Tibi...is first time when you write that cable?
    Look on the picture..
  15. #2355
    DK Veteran KenshinPT's Avatar
    PT
    Well! Better than us you can check if it's ATMEGA or NEC.
    However, if its NEC how can you use an ATMEGA dump and expect to work on the NEC uC?
    I/O, fuses, timers, interrupts are totally different... You won't be able to get that NEC uC working...
    However, I am thinking in something strange... Maybe chinese engies changed the LASER engraving of the ATMEGA to NEC... just to confuse us?
    Why I suspect on that LASER changing? Welll... if Ross Tech doesn't have a VCDS cable with a NEC uC, how can someone adapt an ATMEGA dump to work in a NEC uC?
    IMHO, It's impossible.
    Did it help? Push Thanks below
