Page 158 of 854 FirstFirst ... 58108148153154155156157158159160161162163168208258658 ... LastLast
Results 2,356 to 2,370 of 12803
  1. #2356
    Maybe chineses found a solution... rewrite the flash..for emulate atmega dump..
    On the PCB appear another routes
  2. #2357
    Quote Originally Posted by KenshinPT View Post
    Well! Better than us you can check if it's ATMEGA or NEC.
    However, if its NEC how can you use an ATMEGA dump and expect to work on the NEC uC?
    I/O, fuses, timers, interrupts are totally different... You won't be able to get that NEC uC working...
    However, I am thinking in something strange... Maybe chinese engies changed the LASER engraving of the ATMEGA to NEC... just to confuse us?
    Why I suspect on that LASER changing? Welll... if Ross Tech doesn't have a VCDS cable with a NEC uC, how can someone adapt an ATMEGA dump to work in a NEC uC?
    IMHO, It's impossible.
    What you are hypothesizing is *quite* possible... Not to sound prejudice, but "those damn chinese..."
    I speak from experience. How does the layout compare between the Atmel and supposed NEC uC? Furthermore, has anyone checked to see if Atmel possibly made a pin-for-pin compatible part to replace a NEC part? Shouldn't be hard to determine if the part numbers are etched on the IC's and still legible.
  3. #2358
    DK Veteran obnchip's Avatar
    Dec 2010
    Hi!
    I have vcds 10.63 clone is it possible to use with soft 10.64?
  4. #2359
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by obnchip View Post
    Hi!
    Yes. It's even possible to use with 11.11.0
    Did it help? Push Thanks below
  5. #2360
    cniky's Avatar
    @KenshinPT - you are funny , but you are totally right for an question like this after 158 pages of answers
  6. #2361
    DK Veteran VTS_Tibi's Avatar
    Well, the problem is, that it doesn't have any kind of engraving. It seems like it had when it was made, but now the engraving is sanded out. Seems like the chinese manufacturer did this in order to make his copy uncopiable, or at least to confuse me...
    So I can not tell whether it's Atmel or NEC....
  7. #2362
    UPDATE... seems like the chinese were smart but not enough! I've wiped a graphite pencil over it a few times, and now I can just about read the NEC word...
    ohh well..
  8. #2363
    PT
    Quote Originally Posted by VTS_Tibi View Post
    ohh well..
    Well!
    I though in something that could work:
    1) Decompiling the HEX from the ATMEGA into ASSEMBLY
    2) Understand 100% of that code
    3) Change the ASSEMBLY in order to work with that NEC uC
    However... If they did that:
  9. #2364
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    VCDS 11.11.0 NO DUMP!
  10. #2365
    PT
    Quote Originally Posted by angelx431 View Post
    It exist! You just don't have it
  11. #2366
    Oct 2008
    On Earth
    You talking about dumps or you talking about new chinese tools which works with this version of VCDS?
    Good luck
  12. #2367
    DK Veteran bibkare's Avatar
    B & H
    Kenshin you are on the run ,
  13. #2368
    Sep 2010
    Share with us
    (PM it's a good way)
  14. #2369
    DK Veteran rsibiza's Avatar
    Wink
    Quote Originally Posted by noogi View Post
    Share with us
    Haha...and for sure,free is even better
  15. #2370
    Mar 2009
    https://t.me/pump_upp
    How much does anyone know vcds 11.11 dump
