Page 159 of 854 FirstFirst ... 59109149154155156157158159160161162163164169209259659 ... LastLast
Results 2,371 to 2,385 of 12803
  1. #2371
    Junior Member bat21's Avatar
  2. #2372
    alldecode's Avatar
    EU, Croatia
    If somebody have dump 10.6 and working software to send me.
    I have vcds 805 with BL and 9346 and stop working, update ...
    IF this cable much reflashing with 10.6?
  3. #2373
    Default vag com 10.63
    can someone to tell me if i can update this interfaces to 11.2 without to write gal16v8
    the interfaces use medicated soft
  4. #2374
    Oct 2008
    On Earth
    Quote Originally Posted by nicu_cuc View Post
    Yes you can do it.
    What version it is now?
    Just reflash Atmega use flash pads
    No need to reflash GAL
    Good luck
  5. #2375
    new i used with vag com 10.63 soft but not original soft
    do you thing is a problem if i upgrade to work with original soft?
  6. #2376
    what mince flash pads??
  7. #2377
    Oct 2008
    On Earth
    Near the USB wires there flashing pads.
    You can reflash Atmega using this pads.
    I haven't this kind of tool anymore becasue I use just BL inside tool.
    Do you know how to update it?
    If you know how to update it ou can try the original softwear ( or modified once 10.6.4 and 11.2 ). If you don't ...forget about it.
    It is your choice but this kind of tool you can upgrade it without reflashing GAL for sure.
    Good luck
  8. #2378
    i make upgrade and new i get this error
    can someone to tell me where i wrong
    i write flash and eprom without error
  9. #2379
    DK Veteran mishu_b's Avatar
    Land of Choice!
    as far as I can see it is RL base, and I never succeeded to revival such tool without reprogramming GAL and done the modifications according to RL rules.
    atb
  10. #2380
    Oct 2008
    On Earth
    Quote Originally Posted by mishu_b View Post
    atb
    Misu that it is a new kind of tool.
    You can reflash it without GAL reflashing or others modifications.
    The PCB has the modifications just doneas you do it in the earlier tools with RL.
    The issue it is because I suppose that he need to use a modified softwear tool.
    Good luck
  11. #2381
    do you have modifyed soft for this rl
  12. #2382
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Big D my sincere regards for you
    I couldn't see any STC c.r.a.p. on this pcb, is that why GAL doesn't need flashing. Two years ago I remember i had different kind of pcb in the same case, it was BL based but pcb was really thin and i stopped working with those, maybe this one is better.
  13. #2383
    spychu14's Avatar
    May 2011
    POLAND
    Use with cracked 11.2 from forum.
    Reflash atmega with 1.84 dump and FTDI.
    Don't need to reflash GAL in this hardware
    Anyway it's crappy HW.
    Buy some good clone with FT232BM and ISO drivers like L9637D or si9241.
    VAG
  14. #2384
    Oct 2008
    On Earth
    The new VCDS tools are the same.
    The PCB are the same but the different is that one are with FTDI BL and the others with RL
    The one with BL works with original softwears and for RL's need loader.
    I will ever choose the BL's one.
    You know why.
    This are the good ones
    Good luck
  15. #2385
    didi_du_93000's Avatar
    France Paris
    Default What this???
    Hello all,
    I have chines clone of VCDS 11.2.0.
    full working 1 week ago, but now when i do scan all moduls (in Autoscan menu) i have error " Sorry! this function require a licensed interface."
    And when i turn on the soft i have also the erro:
    "You should update your usbb driver".
    Anyone can help me please?
    Regards.
