Page 162 of 854 FirstFirst ... 62112152157158159160161162163164165166167172212262662 ... LastLast
Results 2,416 to 2,430 of 12803
  1. #2416
    Dec 2011
    Merry Christmas
  2. #2417
    Dec 2010
    Merry Christmas and a Happy New Year!
    can I work this VAG-Com this the HEX-USB+CAN interfaces for VCDS ???
    BR
  3. #2418
    Merry Christmas and a happy new year...
  4. #2419
    DK Veteran KenshinPT's Avatar
    PT
    Merry Xmas and Happy Hacking on VCDS during 2012.
    Did it help? Push Thanks below
  5. #2420
    Hu
  6. #2421
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by KenshinPT View Post
    I couldn't say better then you!
    Marry Christmas to you too!
    atb
  7. #2422
    Merry Christmas!!
  8. #2423
    Hello.
    Need good firmware vcds 11.11
    proposals in a personal.
    Thanks.
    ps.
    Merry Christmas!!
  9. #2424
    PT
    happy 2012
  10. #2425
    Hi!!!
    I need reprogram atmel 162 by UPA, I should resolder atmel or I can reprogram on the board, I should pick up or cuts any legs?
  11. #2426
    ROTIM
    Can be programmed directly into the circuit without the need to cut or lift any terminal, using the ATMEGA terminals 1,2,3,4
  12. #2427
    ROTIM
    happy new year everyone!
  13. #2428
    I will be programmed by UPA, I need to have any special setting lock bits or fuse bits?
  14. #2429
    Sep 2010
    Quote Originally Posted by bodzio012 View Post
    from eXtreme Burner - AVR:
    Low fuse: CD
    High fuse: DC
    Extended fuse: F9
    Lock fuse: FF
  15. #2430
    Jan 2012
    Bucharest, Romania
    Default can I upgrade the interface?
    Hello everyone and a Happy New 2012!
    I own a VCDS 10.6 interface which is equipped with a FT232RL chip. The interface works fine, I'm using it only with the VCDS version that came with it.
    However I have an issue which determined me to try an update to a newer version (11.x). I was recording a log for my 2007 Passat 2.0 TDI 170 hp (the ECU is Siemens PPD 1.2), but the MAF Specified and MAF Actual values (group 003, channels 2 and 3) are absolutely IDENTICAL for all logged timestamps and I suspect a software/firmware related cause.
    Based on the pictures of the interface, please help me with the following info:
    1. what is the main chip mounted on the interface? Is it ATMega or NEC? (it has no marks on it)
    2. is it safe to use the original version of VCDS with this interface?
    3. does this interface support a newer version of VCDS (whether if it is original or specific)? if yes, what steps should be taken in order to enable this?
    4. where can I find the factory dumps for the chips that are mounted on this interface?
    Here are the pictures:
    Thank you for your support,
    Cristian
