hello,
yes i know the answer is in this thread, but I'm french and I'm having a hard time reading the 164 pages of this thread, can you guide me a little please?
thank you for your help, i' m go to prepare the flashing cable.
i need to remove the STC chip, and the T5 transistor and the R50 resistor see on picture?
for run Vcds 10.6... i need to reflash with 1.83 dump?
after reflash, i can run the original software 10.6... or modified software?
thank you for your answers
you need flash and eeprom to reflash Atmega not just flash ( 1.81, 183 or 1.84 )
You need eeprom for VCDS 10.6.0 with flash 1.83 or you need eeprom for VCDS10.6.4 (11.2 ) with flash 1.84
Or eeprom fro VCDS 908 with flash 1.81
And you'll can use original softwears
Good luck
hello,
I have a 805 update to 908.
I can vagcom up to version 10.6 or higher?
Thank you.
and the BL version?
hi, i have the cable v812 with ftdi BM. For BM i can write dump v1.84 and software v11.11.0....where are the files?...i look in this thread but is not easy on 164 pages.
i have dump v1.84 that i found here...is good ?
