Page 167 of 854 FirstFirst ... 67117157162163164165166167168169170171172177217267667 ... LastLast
Results 2,491 to 2,505 of 12803
  1. #2491
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by cadenas View Post
    thank you
    I have the loader of the version 11.2
    how to reprogram the GAL/ATF??
    I do not find the scheme
    Option 1: Welcome to GALBlast
    Option 2: USB G540 Universal EPROM FLASH GAL AVR PIC Programmer | eBay
    Option 3: Simple GAL Programmer at Cool Electronic projects blog
    Good luck
    Did it help? Push Thanks below
  2. #2492
    Default cable version
    hello all,
    if i order this 805.1 version from china (Free Shipping Vagcom VAG Com 805.1 CAN BUS Hex CAN - Automotive - VAG Diagnostic Tools - Door2Door Shop), working good my 805.4 hungarian language version software? or other eprom need to cable?
  3. #2493
    PT
    Quote Originally Posted by jezzus View Post
    hello all,
    It won't work unless you reflash ATMEGA with hungarian 805.4 eeprom dump.
  4. #2494
    What is the latest free version in Spanish? Is there any dump in the forum?
    Regards.
  5. #2495
    Oct 2008
    On Earth
    Quote Originally Posted by esrodi View Post
    Regards.
    Just in English I saw free dump and I suppose in German.
    All others aren't for free.
    Good luck
  6. #2496
    PT
    Regards.
    You can spend around 600? in the Spanish dump or learn English and use the English dump and other english stuff
    Just my oppinion
  7. #2497
    I'm using English version , but I was asking about Spanish because I've seen there are dumps in other languges than English, and I wanted to know whether there was also in Spanish.
  8. #2498
    PT
    I see...
    Keep in mind that the english version has always more features and less bugs
  9. #2499
    Quote Originally Posted by KenshinPT View Post
    I see...
    is not true, for German versions for sure
    if versions is the same, code is almost equal
    I know supplier of cloned interfaces for German, French and Dutch latest versions.
  10. #2500
    PT
    Quote Originally Posted by tk500 View Post
    I understand your point of view but maybe I was not very clear... for example:
    When the 11.11.1 english version was released you can't have the spanish version of 11.11.1 because the latest spanish release is the 10.6.3
    So, if you're using the spanish version, you have more bugs and less features, when comparing to the latest english release.
    source: VCDS VAG-COM DIAGNOSTIC SYSTEM - SISTEMA DE DIAGN?STICO PARA VOLKSWAGEN, AUDI, SEAT Y SKODA
  11. #2501
    For Spanish maybe is true.
    Now German and French vers are on 11.111.
    Sometime betas was released fist on German.
    However Uwe is a German and makes product for German cars.
  12. #2502
    who posted here the schematic with "VCDS GAL equivallence" (russian schematic with NAND gates)? I don't find the post and/or the link...
    I found it
    http://www.digital-kaos.co.uk/forums.../index147.html
    post #2201 - magadan
    Is for RL...
  13. #2503
    RF
    No, it is other microcircuit (for cable on FT232B). But I can make and for "FT232R China". I have no cable of Ross, therefore I do not know as works it ATF.
  14. #2504
    Here, on 2201 post you wrote:
    "If you have "RL" check up a cable with the version of the program 704 or more low. If change is not, check up GAL. I give equivalent the circuit for damp from AGK."
    I suppose that the schematic is for gal for VCDS with RL..
    check your inbox, please.
  15. #2505
    Damp vcds 1.84.
    VCDS 11.2 worked OK!
    Need data return 2010year.
