Page 171 of 854 FirstFirst ... 71121161166167168169170171172173174175176181221271671 ... LastLast
Results 2,551 to 2,565 of 12803
  1. #2551
    Oct 2008
    On Earth
    Quote Originally Posted by KenshinPT View Post
    Well, Now I understand the reason of the STC chip... but if you reflash the ATMEGA with 11.11 dump the next time you plug the cable into 12V the STC will reflash the ATMEGA again to 11.2, right?
    So... I understand that this clone will work with any software version... But in the future Ross Tech will prevent this kind hacking for sure.
    Then you have 3 options:
    1) Use 11.2 dump with the latest working software
    2) Get your hand into a newer dump and use the corresponding software version... For this you must remove STC chip.
    3) Buy original
    No if you upgrade the Atmega you have to reflash it back by AVR programmer
    STC will become unusefull.
    If you reflash Atmega with 11.2 back the STC will become usefull again
    You can use it the dump 11.2 with upper version ( chinese cheat peaple like this ) but will not work well, it become unstable for newer version.
    If you flash the Atmega with upgraded verion the STC become unusefull but the tool become stable.
    So your options are correct
    Good luck
  2. #2552
    DK Veteran VTS_Tibi's Avatar
    Well, on that tool I have - which is now may be in question - I had flashed the Atmega with the 11.2 dump. Read it out, and the dump was correct.
    As soon as I plugged it into the USB port, the content of the Atmega was rewritten....
  3. #2553
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by VTS_Tibi View Post
    So I was right! Every time you connect the cable into 12V the STC chip reflashs the content of the ATMEGA.
    That cable is supposed to be which version?
    Now, it's up to you what you wanna do!
    Did it help? Push Thanks below
  4. #2554
    Ia about this?
    http://www.digital-kaos.co.uk/forums.../index170.html
    Post # 2536?
    Unsolder the stc and reflash atmega. And mandatory uninstall any version of VCDS you have and reinstall 10.6.4 and 11.2.0
    In your first picture you have:
    from left to right upper side = atmega and ftdi
    bottom side= mcp 2551, mcp2515 and 93c46.
    well, 2515 is "20-Lead Plastic Thin Shrink Small Outline (ST) ***8211; 4.4 mm (TSSOP)"?
    I can't see because of bleu wire.. this IC have 20 pins?
    Can you post another photo without programmer wires?
    Thank's
  5. #2555
    I've removed the STC, reprogrammed the Atmega. Now, when plugging into the USB port the content of the Atmega is not rewritten.
    But still, the LED will not light up, and the VCDS gives out the following error:
    Port status: OK
    Interface not found
  6. #2556
    PT
    Port status: OK
    Interface not found
    Hmmm... I think you must plug the cable into 12V.
    Does the cable shows in "Device Manager" as "ROSS TECH HEX-USB"? If not you need to reflash FTDI.
  7. #2557
    It is powered up by 12V....
    And yeah it does show up!
    BTW. It has NEVER worked since I received from the supplier around 2 weeks ago - always the same problem
  8. #2558
    Feb 2012
    you may be full registered to work romanian soft
  9. #2559
    Oct 2008
    On Earth
    Quote Originally Posted by tibygsm View Post
    If you have dump for romanian soft or a genuine tool
    Good luck
  10. #2560
    PT
    Maybe, a transistor, CAN controller, CAN transceiver is/are faulty!
  11. #2561
    Oct 2008
    On Earth
    M8
    Power up the tool
    Go to Option and then TEST
    And what is the message?
    After this in the ABOUT you have to have Full Registred/Activated
    If you have't this you cannot go ahead becasue you didn't reflash it well
    If it's show you Full Registred/Activated then you can check the k-line or the CAN
    Check this first
    Good luck
  12. #2562
    ahadi's Avatar
    hello all ,
    is there any thing about to update VCDS 11.2 11.11 .
    thanks in advance
  13. #2563
    Oct 2008
    On Earth
    Quote Originally Posted by ahadi View Post
    hello all ,
    thanks in advance
    To update the 11.2 to 11.11 it is very simple
    Just update the Atmega with 11.11 dump
    Good luck
  14. #2564
    Junior Member bat21's Avatar
    Everything is simple, even without dump 11.11 is possible
  15. #2565
    Pavel-DN's Avatar
    Nov 2010
    Spain
    Quote Originally Posted by bat21 View Post
    What do you mean? What dump version you talking about?
    Is 1.84 good enough?
    Best regards.
