Page 173 of 854 FirstFirst ... 73123163168169170171172173174175176177178183223273673 ... LastLast
Results 2,581 to 2,595 of 12803
  1. #2581
    Oct 2008
    On Earth
    Quote Originally Posted by tomitomass View Post
    On the Russian web site I found information that firmware 1.84 works fine with all languages. Is this true?
    Mate you read but I suppose that you don't understand everything.
    Atemega dump has two parts
    One it is firmwear - this mean that all softwears from VCDS 10.6.4 till now works with this firmwear 1.84
    This it is necessary in all VCDs languages from VCDS 10.6.4 till now
    And the second part of the Atmega which is the eeprom
    This part eeprom make the diffeent, in this it is the serial that activate the softwear.
    So firmwear it is for all new language versions of VCDS but if you want to activate the softwear you need th eeprom file from dump to make it works.
    I suppose that you understand me.
    Look in the dump posted by miha99
    This dump works with english version
    Good luck
  2. #2582
    Thanks for the reply. I understand that it is enough to change atmega eeprom to run the appropriate language? I am looking for the Polish version. If anyone has please dump the Polish version of VCDs
  3. #2583
    Oct 2008
    On Earth
    It is hard to find for free an english version dump.
    In other languages i suppose you'll never find it for free.
    But this is my opinion
    Good luck
  4. #2584
    DK Veteran KenshinPT's Avatar
    PT
    Yes, you can find (buy) the polish EEPROM but it's cheaper to buy original cable. (and then you can use it with any language) my bad
    Regards.
    Did it help? Push Thanks below
  5. #2585
    Quote Originally Posted by KenshinPT View Post
    buy original cable and then you can use it with any language.
    wrong assumption
    only English work with all interfaces
  6. #2586
    Spain
    Hello.
    I bought this vagcom:
    vag com 11.11(FT 232 BL),
    FTDI232BL... Im using v11.11.1... Can I update to v11.11.2?
    Thanks!
  7. #2587
    Oct 2008
    On Earth
    Quote Originally Posted by DaniXDX View Post
    Hello.
    Thanks!
    You can use it with any versiopn u want but that tool it hasn't dump for 11.11
    Yes you can see that after a while your tool it'll become Unregistred
    You cannot update a clone without dump just if you modify the softwear and use the right firmwear
    Good luck
  8. #2588
    until now I never seen Chinese interface to work with version greater than 11.20
    work with 11.11x but only a few minutes and blocked until replugged
    completely unusable
  9. #2589
    Spain
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Hello!
    I think it does have the dump 11.11, works perfectly well in the v11.11.1 WITHOUT loader.
    How I can check? Thank you!
  10. #2590
    Send me serial number form about window.
    Do not worry, it is from long time in blacklist
    How to check - make few auto scans.
    Software must found all controllers on each scan.
  11. #2591
    Spain
    There is no other way to prove that not doing AutoTest? I have no desire to block.
    I'll send you the serial number when you make "TEST" in the car. You know with the serial number if has a 11.11 dump? (format the pc)
    Greetings.
    Sorry for my English :S.
  12. #2592
    Oct 2008
    On Earth
    Greetings.
    Good idea.
  13. #2593
    Spain
    Good idea.
    Sorry, I dont undersand you.... :S
    Thanks!
  14. #2594
    Oct 2008
    On Earth
    Thanks!
    I said that it is a good idea to tell us the serial
    we can see if it is serial from 11.11 dump or from 11.2
    If you want I will sedn you the VCDS 11.11.0 serial by PM and you can compare with yours.
    I can choose with VCDS 11.11.1 or 11.11.2 but then I have to reflash the tool.
    So in a minutes I will send you the serial by PM and the serial of VCDS 11.11.0 dump using VCDS 11.3
    Just to compair
    Good luck
  15. #2595
    Chinese produce millions of clones with the same serial.
    Few hours after first sells RT put serial in blacklist.
    Any serial used from Chinese does not remain a secret.
    I bet that the serial will be well known - 0001415550275A
