Page 174 of 854 FirstFirst ... 74124164169170171172173174175176177178179184224274674 ... LastLast
Results 2,596 to 2,610 of 12803
  1. #2596
    Jun 2009
    Porto
    Quote Originally Posted by KenshinPT View Post
    You have a good hardware.
    You have only to reflash ATMEGA
    All the info is on this thread.
    Good luck
    I have this 805 interface with the 6 diodes in 2 rows.
    I removed the STC transistor and resistor...
    I flashed eprom and flash of atmega with working files for 11.2...
    I configured locks and fuses as the tutorial on this thread (with UPA falses=0=activated)
    Mprog'd the BL's 93c56
    The interface lights red then green.
    Its detected but gives this on VCDS 10.6.4
    SELF TEST FAILED!
    K1 OK
    K2 OK
    I did the same to a dead 607 interface and the result is the same with 10.6 dumps and soft OR VCDS 805 dumps and software...
    I even wrote the ATF or GAL in these interfaces...
    Tried exchanging MPC etc etc to no success...
    I'm feeding only 12v and GND but i have also tried in a car.
    Tried in VMware 10.6.4 and 908.
    What the hell is wrong?
  2. #2597
    Jun 2009
    Porto
    This is what i get in 10.6.4 and 11.2 beta TEST screen.
    In both interfaces (805 and 607).
    Where is CAN not ready?????
    There was a shorted transistor in 805 that i replaced. maybe it damaged the can ic?
  3. #2598
    This message appear to me when the eeprom.bin was wrong..
  4. #2599
    Jun 2009
    Porto
    Hello liviudiaconu,
    You mean the boot eeprom or the 93c?
    Thank you
  5. #2600
    Oct 2008
    On Earth
    He means the Atemga eeprom.bin
    Good luck
  6. #2601
    Jun 2009
    Porto
    just tried more MCU eeproms and flashs and same results.
    I tried also with 805 dumps and VCDS and result its the same (self test failed) except fw is 1.78...
    BTW the 805 atmega had originally this config in lock bits:
    LB1 0
    LB2 0
    BLB01 0
    BLB02 0
    BLB11 0
    BLB12 0
    I used the config from the tutorial with BLB01 and 2 disabled ( = 1)
    Can it be hardware that is messed up?
  7. #2602
    pt
    hi
    i look for vcds 11.11.x flash and eeprom
    please send offers to pm
    regards
  8. #2603
    Jun 2009
    Porto
    It was the files... they were just wrong...
    thanks!
  9. #2604
    Feb 2012
    Hi guys, I have encountered several comments on tutorial to re flash the hex+CAN adapter and don't seem to be able to find one. Can anyone point me to the right place?
    Alex
  10. #2605
    DK Veteran KenshinPT's Avatar
    PT
    Hey mates!
    Do you have a VCDS clone cable which you want to dump the EEPROM?
    PM me please if you have:
    - English 11.11.0 or higher
    - Any other language clone version (Romanian, Russian, German...)
    There is no point to dump EEPROMs like English 605, 704, 805, 908, 10.6.4, 11.2... Those are already posted in this thread.
    Regards!
    Did it help? Push Thanks below
  11. #2606
    Does anyone have a loader for VCDS 11.11 with FT232RL?
  12. #2607
    Spain
    Quote Originally Posted by mattydr67 View Post
    I said that it is a good idea to tell us the serial
    we can see if it is serial from 11.11 dump or from 11.2
    If you want I will sedn you the VCDS 11.11.0 serial by PM and you can compare with yours.
    I can choose with VCDS 11.11.1 or 11.11.2 but then I have to reflash the tool.
    So in a minutes I will send you the serial by PM and the serial of VCDS 11.11.0 dump using VCDS 11.3
    Just to compair
    Good luck
    Hello friend!
    I compared and the serial, and is similar to 11.3 that sent me by PM (thanks).
    I include it here ...
    Uploaded with ImageShack.us
    I have seen a similar serial using the 11.3, I can install myself? Or what is the latest version I can use this serial?
    Now I'm using 11.2, but I have to delay the date on your computer to work ... Is this normal? Be solved?
    Thank you!
  13. #2608
    Quote Originally Posted by DaniXDX View Post
    Hello friend!
    Thank you!
    Quote Originally Posted by tk500 View Post
    I bet that the serial will be well known - 0001415550275A
    and I am the winner.
    with this serial cable is totally unusable with 11.11x
    It can work with old version market as "stable" in china CD
    But 11.112 is super stable ...
  14. #2609
    Oct 2008
    On Earth
    Hello friend!
    Thank you!
    I didn't sent you this serial
    Here it is VCDS 11.3 using 11.11.0 dump
    Good luck
  15. #2610
    Spain
    If you are the winner. hehe.
    So what I recommend that you use, 11.2? As I can make it work without delaying the date on PC?
    Thank you!
    @ mattydr67, the serial to 11.2 is: 014 155-50275th-hex7386-044127-5153-bjhahh
    Thanks!
