Page 177 of 854 FirstFirst ... 77127167172173174175176177178179180181182187227277677 ... LastLast
Results 2,641 to 2,655 of 12803
  1. #2641
    Top Poster + mladen76's Avatar
    By the see
    Can't belive that that is a reason???
  2. #2642
    Quote Originally Posted by magadan View Post
    1) Original Inglish 10.6.1.
    2) And I want to receive the Original Inglish version the program in which is HCC182.bin. If the such exists.
    hmmm, sorry, checked my collection and I found only last final version (704.1, 805.4, 908.2, 10.6.5, and all 11.x)
  3. #2643
    GB
    USB\VID_059b&PID_0251 neeeeeeed heeeelp pls . how to repair my ftdi???????
  4. #2644
    GB
    how to remove black listed serials or .....
  5. #2645
    Top Poster + randomlog's Avatar
    Argentina
    Quote Originally Posted by iustin73 View Post
    you need this drivers: http://www.digital-kaos.co.uk/forums...8/#post1488361
    Admin of Audi Forum Argentina.
  6. #2646
    Mar 2012
    Hey. Atmega126 programmed correctly. VCDS 908th Do you have a simple diagram of how to program the GAL? Thanks
  7. #2647
    Mar 2012
    On the basis of this schema to someone able to program the GAL?
  8. #2648
    Mar 2012
    The last question . Do GAL16V8B reads in the system or outside?
  9. #2649
    DK Veteran mishu_b's Avatar
    Land of Choice!
    outside !!!
    and be careful with GAL devices - they are very very sensitive to programmable voltage.
    atb
  10. #2650
    fuktak's Avatar
    Sep 2010
    Bulgaria
    That is picture from vcds without GAL from other forum
  11. #2651
    Mar 2012
    Quote Originally Posted by ~~~tak View Post
    Plugged the GAL in as written. I loaded the "flash183" and installed "VAG908_Installer_v160". Results as in the pictures. Here is the package which loads into VCDs. http://hostuje.net/file.php?id=fabd8...c54ca714b6db3a
  12. #2652
    Land of Choice!
    Quote Originally Posted by tricoredc17 View Post
    check security bytes!
    atb
  13. #2653
    Mar 2012
    Quote Originally Posted by mishu_b View Post
    atb
    That is:
  14. #2654
    Junior Member max4ever's Avatar
    Romania
    Write all (flash and eeprom) and check again!
  15. #2655
    Mar 2012
    My VCDS now looks like this:. But it still does not work. The green LED lights up.
