Page 179 of 854 FirstFirst ... 79129169174175176177178179180181182183184189229279679 ... LastLast
Results 2,671 to 2,685 of 12803
  1. #2671
    Oct 2008
    On Earth
    Quote Originally Posted by tricoredc17 View Post
    I have the VP-590 Programmer. He does Gale. Only I do not dump for it: (
    This is not a problem
    I will send it to you
    Good luck
  2. #2672
    tricoredc17, check PM
  3. #2673
    DK Veteran mishu_b's Avatar
    Land of Choice!
    you have here all you need.
    Digital Kaos
    atb
  4. #2674
    Mar 2012
    I found the layout of the house PALCE 16V8H - 15ji / 4. Is it possible to use this trick?
  5. #2675
    Top Poster + randomlog's Avatar
    Argentina
    Hi, i want to reprogram atmega162.
    i have upa and xprog.
    How can i reprogram without soldering and desoldering?.
    Exists some tool like test clip / 3m ic test to do that?
    Thanks in advanced
    Admin of Audi Forum Argentina.
  6. #2676
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by randomlog View Post
    Thanks in advanced
    You don't need a clip. Just solder 4 wires directly in the ATMEGA.
    Did it help? Push Thanks below
  7. #2677
    Some models of vcds have pads for programm on margin of PCB, beside USB cable pads.
  8. #2678
    PT
    You're right! I was working in a friend's cable which as those terminals. It's much easier to reflash the ATMEGA.
    Another curious thing is one cable I have: if the USB is not plugged you can't reflash the ATMEGA.
    The programming software says that can't find the uC.
    If you plug the USB terminal, the reflash works like a charm
    You guys should keep this in mind to prevent troubles in the future...
    My guess is that 5V at the output of the 7805 are not powering up the ATMEGA, instead the ATMEGA is powered via USB!!!
    Good luck!
  9. #2679
    Austria
    Anyone has lattest working dump? 11.11.2?
  10. #2680
    RF
    I know as to make a clone from an original cable on chip FT232R. And I know as to force this EEPROM from atmega to work at other cable. Who wants to make a clone from the original cable, write to a PM.
  11. #2681
    Quote Originally Posted by KenshinPT View Post
    Good luck!
    Have you an ohmmeter? Or voltmeter?
    Try this: with ohmmeter the continuity between Vcc of ATMEGA and pin 3 of 7805.
    with voltmeter with cable plugged at 12V..check +5V Vcc of atmega and after with only usb pluggged, check +5V Vcc Atmega. And you'll see where is powered..
  12. #2682
    Mar 2012
    thanks tbiliszi
  13. #2683
    PT
    I have a multimeter! But I don't even bother because that's the only thing that makes sense.. that is... the ATMEGA is powered up via USB and not via 7805.
  14. #2684
    PT
    Quote Originally Posted by magadan View Post
    Hey mate!
    Can you explain how to you mod the VCDS.exe to bypass the FT232RL signature?
    Regards.
  15. #2685
    RF
    If you use RL you need to bypass the FTDI signature.
    It is impossible to tell this information at a forum. Write to me to a PM.
