Just updated to 908 and now it says not fully activated/registered.
Did TEST and SAVE with cable pluged to car.
any sugestions?
Thanks in advance
You can wire directly a programmer (ISP programming) into the GAL only if the GAL is an ispGAL. If not, you must dessold it and program it externally.
Here you have two cheap GAL programmers:
ELM - Simple GAL Programmer
http://www.armory.com/~rstevew/Publi..._ClikMe1st.htm
I am looking to see if i have a contact that can program it for me, soldering is easy![]()
Interface test is ok,
Done all procedures still says shareware/not ativated in ABOUT icon.
And when try to do some basic test to car it says "you need a licenced interface to use this funcion".
Already uninstalled vag908 and also drivers and then instaled it again and same thing.
Do i need to reprogram again the cable or its just a software/drivers issue?
HI xoom or Bibikare
even i try to erase the ft232rl with ftprog under WIN XP.
but when i select the eeprom i make a right click an the eeprom chose erase and now following error occur what is may fault. see attachment
Furthermore for examble the eeprom is erased than i click open template-> chose the flash than i select the eeprom make a right click on it chose program Device?
What is the button Flash Room?
Try just overwrite eeprom..
