Page 181 of 854 FirstFirst ... 81131171176177178179180181182183184185186191231281681 ... LastLast
Results 2,701 to 2,715 of 12803
  1. #2701
    ahadi's Avatar
    Quote Originally Posted by mattydr67 View Post
    Next dump it is 11.11.0
    From 11.2 to 11.11.0 no other dump
    Good luck
    Thank you .
    if you have 11.11.0 dumps ,please upload .
  2. #2702
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by ahadi View Post
    Thank you .
    Too good to be true!
    11.11.0 is not for free, yet
    Did it help? Push Thanks below
  3. #2703
    Pancevo, Serbia
    Quote Originally Posted by dorcky View Post
    Here is the interface that replaces the SI9241AEY with transistors, for those who want to build the interface and not able to get that ISO transceiver.
    Attachment 13141
    Regards!
    Thank you!
  4. #2704
    Mar 2012
    Has anyone programmed GAL system programmer VP-590?
  5. #2705
    Quote Originally Posted by tricoredc17 View Post
    I have not used VP-590 but VP-290 for GAL programming.
  6. #2706
    Mar 2012
    Quote Originally Posted by Qwarz View Post
    What exactly the system you choose?
  7. #2707
    I have been using Windows XP (32-bits) with Wellon softawre in ver.: 4.3.3 (2011-11-28)
  8. #2708
    Mar 2012
    What you choose gal in wellon
  9. #2709
    I choose: Manufacturer: Lattice, device: GAL16V8D*20PL
  10. #2710
    Mar 2012
    What Bin programmed?
  11. #2711
    I have bin using not bin but jed file
  12. #2712
    Mar 2012
    Can you litter the JED?
  13. #2713
    I can of course
  14. #2714
    Apr 2011
    Cheyenne, WY
    Quote Originally Posted by Drsplock View Post
    Had problem today, got VW polo 2001, reads all other controllers ok but not 01 ? any ideas please.
    Address 01
    Protocol: ????
    Controller:
    Note: Can't Synch Baud Rate
    Address 03
    Protocol: KW1281
    Controller: 6X0 907 379 B
    Component: ABS 30 IE CAN V004
    Coding: 05603
    Shop #: WSC 00788
    Skipping Address 15-Airbags
    Address 17
    Protocol: KW1281
    Controller: 6N0 920 904 D
    Component: KOMBIINSTRUMENT BOO V09
    Coding: 00441
    Shop #: WSC 65793
    Address 19
    Protocol: KW1281
    Controller: 6N0 909 901
    Component: Gateway K<->CAN
    Coding: 00022
    Shop #: WSC 00788
    Is not this year 2001 a chipped ecu; can not be flashed...
  15. #2715
    Jan 2012
    Default New vcds clone solution
    My friend bayed vcds 10.6.4 clone and bricked it.
    Its looks like genuine interface!!!
    Hardware is different than on this forum listed,
    it has :
    atmlh134 you can erase it as 93c46
    Before programming atmega162 you need to remove
    STC11F01 security chip!
    Thats all, it works!
