Page 185 of 854 FirstFirst ... 85135175180181182183184185186187188189190195235285685 ... LastLast
Results 2,761 to 2,775 of 12803
  1. #2761
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by KenshinPT View Post
    Anyone know if a eeprom dump from a cable based on a FT232BL could work on a cable based on a FT232RL? After modding the harware and using a loader.
    And the other way around? A eeprom dump from a cable based on a FT232RL could work on a cable based on a FT232BL?
    I use same dump for RL and BL, difference is using loader with RL
  2. #2762
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by magadan View Post
    It can work and on the contrary if to use other loader.
    Here proof.
    It is a clone of a cable based on the FT232R chip.
    Quote Originally Posted by bibkare View Post
    So, If you buy original cable with FT232RL, and imagine that you could dump the flash+eeprom... Would you be able to use that RL eeprom dump on a cloned cable with a BL FTDI? Without any loader or modding the eeprom?
    Did it help? Push Thanks below
  3. #2763
    OK, i thought i found a 11.2 loader version but the cable when plugged in to the car is unregistered/unauthorised. I can see the licence details so atmega must be OK.
    i am going to try 10.6.4.
    cheeky question, is loader 11.2 on here? used search and can't find it
  4. #2764
    RF
    The chance of repetition "ChIP-ID" for all chips FT232R on Ross's algorithm is equal 1 option from 65536 options.
    Therefore there is a possibility to buy in shop the necessary chip, and to use a clone.
    This chance even is a little higher, for some ChIP-ID.
  5. #2765
    B & H
    Here you go Taz
  6. #2766
    Works perfect, thank you for your help.
    is 11.2 the best i will get in its current state?
  7. #2767
    RF
    Here you go Taz
    Or there are here these loaders. They lay on a rutracker.
    Place in the folder with the program. Start not VCDS.EXE , and this loader. Or make a label on necessary a loader.
  8. The Following User Says Thank You to magadan For This Useful Post:
    seal777 (8th April, 2021)
  9. #2768
    Dec 2010
    I have VCDS1062 with chip 079F8513A(CHINA).What is it?
  10. #2769
    Oct 2008
    On Earth
    Quote Originally Posted by Sergey99 View Post
    I suppose that it is NEC not Atmega
    If it is so you'll not be able to upgrade it or reflash it.
    F...k this It is a sh..t
    Good luck
  11. #2770
    But the relevant data is after 40h, right?
    Hi I have 908 version with 232 BL and after long time working good when I plug in the car got eror with interface.When I test it got** Not pluged in the car**but it see Ross tech interface.I readed atmega and in eprom where is FF placed by me is all 00 is it ok or I should write FF inside I programed another flash but same?Thanks
  12. #2771
    PT
    Quote Originally Posted by antibisic View Post
    Which error do you get when you connect the cable into the car?
  13. #2772
    I get** interface is not ready**posiblle cause wrong com port,firmware update need and so on
  14. #2773
    PT
    Try to flash again the ATMEGA and FTDI.
    Then post results.
  15. #2774
    Then post results.
    I reflashed atmega with files 908 here from forum and 93c46 too with diferent ept but still same message that interface is not conected in the car when I test interface!What else can be reason?Thanks
    Before this hapened sometimes I get this message too and I disconect and conect interface end it worked
  16. #2775
    PT
    Take some high quality pictures from both sides of the PCB.
    Make sure that the photos show clearly the IC's labels.
    Good luck
