Page 188 of 854 FirstFirst ... 88138178183184185186187188189190191192193198238288688 ... LastLast
Results 2,806 to 2,820 of 12803
  1. #2806
    Mar 2012
    Quote Originally Posted by KenshinPT View Post
    Yes.
    Regards.
    Just ask him. You are reading connecting to atmega162? Is the USB port? I think we have the same patent
  2. #2807
    matekhr's Avatar
    Croatia
    Quote Originally Posted by mattydr67 View Post
    That is NEC not ATMEGA
    You have bad luck in this case becasue for this kind of tools there's no solution, I mean no dump for NEC
    Try to reflash it with MProg maybe you have a littel luck and it will work but in other case you have to buy another tool.
    Good luck
    Have you any datasheet for this? It doesn't seem to be pin-compatible with Atmega.
    (I'll try some other VCDS versions, maybe it will work with some earlier release.)
  3. #2808
    Oct 2008
    On Earth
    Quote Originally Posted by matekhr View Post
    It is not compatible with Atmega.
    It is other Chinese chip and there's no dump for it.
    It is working just with VCDS 10.6.0 or if you make a loader will work with other versions too.
    But as I told you if you wanna reflash this tool you'll not be able becasue there's no dump for NEC
    Sorry for your inconvenience but this is it, you have nothing to do.
    Good luck
  4. #2809
    matekhr's Avatar
    Croatia
    Good luck
    Well, my PC recognizes the cable OK (as Ross-tech interface), but after connecting it to car (or 12V) I got the message (something like that):
    "Port status: OK, Interface: No"
  5. #2810
    Junior Member bat21's Avatar
    Quote Originally Posted by tricoredc17 View Post
    Is simpler way
  6. #2811
    DK Veteran KenshinPT's Avatar
    PT
    Yes... I believe that we have the same method to extract the dump from ori or clone tool.
    The only difference in our methods is that I don't ask 500? for that. I just ask for friendship.
    Regards.
    Did it help? Push Thanks below
  7. #2812
    Oct 2008
    On Earth
    Plug it into the car do not start the engine.
    Then plug it into the USB and check in the Device Manager if it recognized and the VID/PID it is 0403/FA20
    Then make an interface TEST and see in the same time if you loose uSB connection.
    Or try it to Read it with MProg or use the ept file and try to reflash it.
    If it said the it dosen't found the tool this means that FTDI it is broken.
    Change it and you have a good tool again. Ovi_dk had same issue
    Good luck
  8. #2813
    xoom's Avatar
    Ylakiai
    My old vag-com cable makes me a lot of troubles, so I ordered a new one. It arrived yesterday, didn't work (of course) so I opened it.
    Instead of Atmega there's a chip marked D79F8513A (China).
    What a hell is that?
    Try with older versions of VCDS like 805 - 912..
    Also check for solder splashes between chips legs this is often in chineese stuff
    Regards, xoom.
  9. #2814
    Hi friends. I have a weird issue with a Vag10.6 clone cable interface. After a year of usage with almost no troubles, today trying to scan my own car with it, I notice a weird notice from the software indicating me interface detected but car not connected!!!!!. I try every module that I can and I got the same message. I plug and unplug it several times and the result was the same. Also I notice that the interface got hot, touchable but hot!!!!!!. I test my old KKL dumb interface and it reach every module of the car. Anyone had the same issue??? What could be the problem???? I really appreciate your advice friends.
  10. #2815
    PT
    Quote Originally Posted by xoom View Post
    Regards, xoom.
    You're right.
    I had a bad experience in one of my cables.
    The FTDI was full of solder flux and that was making a low impedance between pads: Conclusion: bad behaviour.
  11. #2816
    Quote Originally Posted by eliotroyano View Post
    Hi again friends. Here is a pic of the issue that I have.
  12. #2817
    Oct 2008
    On Earth
    What about the LED?
    Is it turned on?
    If yes in this case you'll need to reflash it.
    Good luck
  13. #2818
    What about the LED?
    Is it turned on?
    Good luck
    When the cable was working, just after plug it to the OBD2 port the LED blinks red some times and get green. Now it blinks several times in red and after that it turns off. And when I try to diagnose some car module it starts to get warm and hot but touchable.
  14. #2819
    matekhr's Avatar
    Croatia
    It works with 908
    And the firmware is 1.81, but because it's NEC MCU inside instead of Atmege, I suppose it's not upgradeable?
    It's not what I expected, because the cable is declared as 10.6, but at least, it works...
    Maybe I should update my old cable to higher version - it's 7.04 with FTDI232BL and 93c46 eeprom. What can I do with it?
  15. #2820
    PT
    It works with 908
    Hey!!! That's great news!
    Regarding the 704 I bet you have a good hardware. If so, you can upgrade it to any available dump
    Good luck.
