Page 196 of 854 FirstFirst ... 96146186191192193194195196197198199200201206246296696 ... LastLast
Results 2,926 to 2,940 of 12803
  1. #2926
    Oct 2008
    On Earth
    You need to flash the Atmega first and then you ahve to isntall the VCDs 11.11.0 softwear and if you want that your tool to work you need a loader becasue you've got a RL tool
    Good luck
  2. #2927
    Mar 2012
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Send me the loader? Thanks
  3. #2928
    DK Veteran KenshinPT's Avatar
    PT
    Hey mates!
    Anyone saw one of this?
    Any help will be appreciated
    Regards.
    Did it help? Push Thanks below
  4. #2929
    Austria
    what help do you need, or what problem do you have?
  5. #2930
    Quote Originally Posted by KenshinPT View Post
    Hey mates!
    Regards.
    It is the NEC chip with firmware 1.84.
  6. #2931
    PT
    Quote Originally Posted by oep View Post
    Look at the ATMEGA, or should I say NEC?
    Anyone knows how this works? How the FLASH and EEPROM of an ATMEGA can be fitted on another uC?!
    I don't even find the datasheet for this chip! ^^!
  7. #2932
    Austria
    i know, and so far never seen anyone except mr lee has dump for this
  8. #2933
    Oct 2008
    On Earth
    Quote Originally Posted by tricoredc17 View Post
    I cannot
    Sorry
    Good luck
  9. #2934
    Oct 2008
    On Earth
    Hey mates!
    Regards.
    As I told you a PM before buy this kind of VCDS, I haven't see any dump for this yet
    Good luck
  10. #2935
    PT
    Good luck
    I am working out this with the seller... the seller thought that this had an ATMEGA.
    Thank you though
    About the datasheet... anyone know where I can find it?
  11. #2936
    RF
    Thank you though
    In this controler flash volume more than in atmega. And speed of operation is higher. Chinese wrote the environment emulator atmega. Also used a flash and eeprom from atmega (v 11.2).
    So I think.
    I tried to write such emulator itself. But couldn't. Knowledge didn't suffice.
    Also Chinese disconnected an update of a flash of this cable through USB-port. I wanted to load a special flash in a cable to get full access to the controler as I did it on a cable with atmega. But it turned out nothing.
    And in your cable, already something new. There is no GAL, probably in the emulator registered also switch functions. But can already and own flash wrote.
    In the free access I this flash didn't see. And this flash isn't necessary to professionals. Therefore it is necessary to look for the Chinese author.
    Here it is datasheet on the similar controler.
  12. #2937
    Junior Member bat21's Avatar
    do-it-yourself, easy
  13. #2938
    Mar 2012
    Quote Originally Posted by bat21 View Post
    Hint what to do
  14. #2939
    PT
    Hint what to do
    Ollydbg 75 04 -> 75 00
  15. #2940
    RF
    Addr: 004**E6*.......04......00
