Page 197 of 854 FirstFirst ... 97147187192193194195196197198199200201202207247297697 ... LastLast
Results 2,941 to 2,955 of 12803
  1. #2941
    Mar 2012
    Quote Originally Posted by magadan View Post
    Addr: 004**E6*.......04......00
    In what program?
  2. #2942
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by tricoredc17 View Post
    In what program?
    - Ollydbg to spot it.
    - DUP to create a loader.
    Good luck
    Did it help? Push Thanks below
  3. #2943
    Mar 2012
    A good program? Well I start? Little help
  4. #2944
    pt
    hello guys
    please someone can give some help i want to reprogram this chinese vcds withft232BL
    I know T5 and IC8 must be removed just not sure wich resistores must i take also.
    zecas
  5. #2945
    Mar 2012
    Quote Originally Posted by zecas View Post
    hello guys
    zecas
    1. T5 and IC8 - remov
    2. Reflash GAL16v8
    3. Reflash Atmega126
    4. Reflash FT232BL (MProg)
    5. Install and run VCDS.
  6. #2946
    PT
    2. Reflash GAL16v8
    1. T5, R50 and IC8 - remove
    2. Reflash GAL16v8 // not needed
    3. Reflash Atmega162 //OK
    4. Reflash FT232BL (MProg) //OK
    5. Install and run VCDS.[/QUOTE] //OK
  7. #2947
    for 11.11.0 you canot use dup to make loader
  8. #2948
    RF
    Quote Originally Posted by cosmind View Post
    It is necessary to use time delay that the program managed to finish check of an image.
    There are still difficulties, but they will begin, when will expire a program expiration date.
  9. #2949
    Feb 2011
    France
    have you a name of a loader that can use delay before patching ?
    Thank
  10. #2950
    PT
  11. #2951
    With posted hire serial will work only few mins.
    And if is that serial, no need to be hidden - already is black listed.
  12. #2952
    PT
    Quote Originally Posted by tk500 View Post
    This is not yet blacklisted
  13. #2953
    May 2012
    VCDs have an interface with FT232RL 10.6.0. I care if I do upgrade to 11.2. If so, how?
    A good day.
  14. #2954
    Shmortz's Avatar
    in the middle of nowhere
    Quote Originally Posted by mattydr67 View Post
    You can do like this:
    1. Plug the interface to the USB
    2. Go to Device Manager and uninstall the driver
    3. Unplug the interface
    4. Replace the RT-USB.inf from VCDS folder with this one
    5. Plug the interface to the USB
    6. Run MProg and then flash the interface with this ept. file
    You know how.
    1. Upload the ept file
    2 Read
    3 Erase
    4 Flash
    In the end unplug the inetrface and then plug it in back
    Go to the Device Manager and you'll see that it will be recognized as Ross-Tech Hex CAN USB interface.
    In the VCDS folder set USB before testing ( nom com port )
    Good luck
    I'm trying this with VAG KKL USB blue and no success, Mprog and FT prog still shows that device is blank, please help to reprogram FT232BL.
  15. #2955
    PT
    Quote Originally Posted by Shmortz View Post
    This is not a HEX-CAN, however you can reflash the FTDI with Mprog.
    Open Mprog and click "Scan for available devices"
    Then upload the *.ept file
