Page 19 of 854 FirstFirst ... 914151617181920212223242969119519 ... LastLast
Results 271 to 285 of 12803
  1. #271
    Nov 2010
    i have one Problem
  2. #272
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by Nemesiz12 View Post
    There is not button with overwrite eeprom!
    i mean just read your ft232rl and then pres right button on device witch appears in ft_prog.. then choose Apply Template > From File..
  3. #273
    Oct 2010
    Quote Originally Posted by xoom View Post
    HI
    now i have programmed the ft232rl i used Mprog. Windows recognized the cable now a rossTech thank you very much.
    Now i solder the hardware to flash the atmega like the tutorial but in the tutorial
    is a step (the first part) to flash the ft232rl with vidpidfix but even i have flash the ft232rl with Mprog can i skip this step?
    to flash the atmega i have to use ponyprog as flash file
    i have two .hex files a eprom.hex and flash.hex in the tutorial is one .bin file
    in ponyprog i can chose as file end .hex but witch .hex file flash ore eeprom .hex?
    ore what i must do with the two hex files?
    I need a bin file?
    Thank you
  4. #274
    Nov 2010
    Quote Originally Posted by talala View Post
    i have one Problem
    any help pls.
    thank
  5. #275
    Oct 2010
    any help pls.
    thank
    read this forum
    Repair your vag-com 704.1 step by step - Page 3 - GSM-Forum
  6. The Following User Says Thank You to Nemesiz12 For This Useful Post:
    ecufix (14th March, 2021)
  7. #276
    DK Veteran bibkare's Avatar
    B & H
    HI
    I need a bin file?
    Thank you
    S.hit man i told you this before, you even thanked me for this, read this post again http://www.digital-kaos.co.uk/forums...tml#post827511
  8. #277
    Oct 2010
    Quote Originally Posted by bibkare View Post
    Sorry bibkare,
    i have forgot this post.
    please be cool :-)
  9. #278
    B & H
    Sorry bibkare,
    please be cool :-)
    No worries man
  10. #279
    Nov 2010
    if i open
    vidpidfix.exe
    no device attached
    wenn i atctced usb in my laptop wunted to install Ross-tech drive.
    any help PLS.
    thank
  11. #280
    Oct 2010
    Flash order: first write ftdi eeprom with appropriate dump for ft232rl or bl, use mprog or ftprog acordingly. For this you don't need any soldering, just connect interface to usb port (all this is very well explained in tutorial)
    second: connect wires on your atmega like in tutorial and supply power to interface, open ponyprog choose first flash file (extension .hex) then choose eeprom file (also .hex extension) program it. Forget about .bin file, use arash dump with two files
    Hit thanks button if this helps
    Hi bibikare
    how ponyprog now witch file is write into the flash and witch hex file into the eeprom? I only have the button open file and write. I have to choose anywhere write into flash and write into eeprom?
  12. #281
    xoom's Avatar
    Ylakiai
    HI
    I need a bin file?
    Thank you
  13. #282
    Oct 2010
    yesterday i want to solder my cable to flash the atmega. But before i do this i have try the cable on my car and what should i say the cable works. I only have flash the RFT232RL.
    But Why?
    After I killing the cable with VCDS 10.6 from rosstech website windows detect the cable as USB to serial I have flashed the rft232rl an the cable do again the job.
  14. #283
    B & H
    But Why?
    Hmm, try function autoscan, if that goes well i mean if you don't get message "this function require licensed interface", then you are OK. I sincerely doubt that your cable was cured
  15. #284
    Oct 2010
    yes autoscan work perfect I use this cable with VCDS 908 on a Golf 6. I can read every control modul.
    Because Why?
    I have try to use VCDS 10.6 -> choose test
    cable wars recogniced 1 minute later Windows occures a message unknown device USB to serial. The cable do not work with the Original VCDS 10.6 and my clone VCDS 908.
    I flashed the rftl232 an the cable work again with the clone 908 sotware. I do not trust me to test it again with the 10.6
    can I test any other cloned VCDS software with a higher release?
  16. #285
    B & H
    Because Why?
    Don't use it with higher version, be happy with 908, i am very glad that you managed to work again bravo
