If in your cable is FT232B and isn't present 93?46, then VID-PID will be equal 0403-6001. And the cable will work as com-port. If it not so, 93?46(or 93C56) is present at your cable.
Here dumps for USB-cables are placed. If your cable is calculated for com-port, you should seal 93?46, and then to program MProg.
I thought everything it will be simple.
In the 64th bit system of a command of the assembler have other codes, and Olly debager isn't suitable for these programs. At me there is no time to study the 64th bit assembler. Use the 32nd bit file vcds.exe together with a loader.
does anyone have the 32bit 11.11 with loader? i tried the 11.11 file supplied in this thread but it did not work. i have uninstalled 11.11 now so my 11.2 is not broken.
This is 11.11.0 and his loader.
But do you have a good-working eeprom dump for atmega?
I use VAG COM 11.11 cable
but I CAN'T delete fault codes from AirBag..
any solution?
firmware its 1.84
If your tool is good, I mean it is full Activated/Registred maybe you need to see what exaclly DTC you have and use the solution to fix that issues. Then you'll be able to erase the DTC
If you have Crash Data DTC don't use the VCDS becasue it is not usefull and you waist your time with it.
Good luck
Where can I find driver for 11.11 VCDs? What you posted does not contain drivers for the cable.
Mate all VCDS installers, no metter what version item are, the drivers it is installed in the same time with softwear.
So the drivers it is conetent into the VCDS folder where it is installed ( as C:\Ross-Tech\VCDS ) and it is called RT-USB.inf
You can brows to this folder if you cannot install drivers automatically
Good luck and enjoy
