I now how to program ftdi. What I don't understand is how to flash 93c with mprog. I have bin file for 93c
So first i program ftdi with it's ept file and recycle it ,then what , how to open 93c file?
Ok thanks , i thought that i'm missing a part here. Anyway i had flashed atmega (write and verified OK) but i have blinking red led. Cable shows ok on hardware devices but when connected to car with it shows not connected to car. Tried different 11.11 atmega file but with same error
Mate
The bin file is for the eeprom when you flash it using an external programmer.
If you use MProg using USB connectio true FTDI you need the ept file.
So it is your choice. If you like to reflash the 93Cxx true USB you can use MProg.
If you like to reflash the 93Cxx directlly with an extrernal programmer you need the bin file
Good luck
Tell someone how to draw input from the program VCDS PETools?
Polish dump 10.6.5 work with FT232BM/BL
Only for 100+ post members - password by PM![]()
VAG
